Building a 383.
Old Jun 10, 2005 | 06:46 PM
SonnyMarrow's Avatar
SonnyMarrow
7th Gear
Default Building a 383.
I know what components to purchase and how to do all the work, but what I am having trouble with is sorting through all the different manufactures. I have been out of the loop for a while and have lost track. I like Edelbrock parts and will use their 70cc 2.02 heads and High-rise intake. Any suggestions for the other necessary parts, such as forged flat-top pistons, internally balanced crank, cam, etc. Money is no issue. I am just curious which parts are the highest quality and will yield the best performance.
Old Jun 10, 2005 | 08:44 PM
b71vette's Avatar
b71vette
Default I just had a 383 built here is my parts list
350 C.I.Seasoned Block Cast#3970010
Scat 9000 Series Stroker Cast Steel Crank 9-350-3750-5700B* Serial# 05A217
Scat 6" I-Beam Connecting Rods CR6002
Race series Rod bearings
Race series Main Bearings
JE SRP Forged Pistons 138093
JE SRP Piston-Rod pins 927-2750-15-515
JE SRP Piston-Rod pin locks 927-042-CS
Oil Ring Support Rails RA4030-183
AFR195cc CNC Ported Aluminum Heads w/ Straight Plugs,Teflon PC Valve Seals,Stainless Steel Valves 1036
ARP Head Bolts 134-3601
Comp Cams Mechanical Roller Cam 12-769-8
Comp Cams Valve Springs 977-16
Comp Cams Valve Spring Retainers 740-16
Comp Cams Timing CS Magnum Roller Set 2100
Comp Cams Mechanical Roller Lifters 818-16
Comp Cams 11/32 Super Locks 611-16
Comp Cams ID Spring Seat 4771-16
CAT Power Products Extruded Aluminum Roller Rockers RKE302B 1.6
CAT Power Products Extruded Aluminum Stud Girdles SG-20016
Melling Oil Pump - High Volume M-55HV
Melling Oil Pump Shaft IS-55E
ARP Hex Oil Pump Stud Kit 230-7001
Professional Products 6.75" Harmonic Damper 8000
Moroso Oil Pan 20188
Moroso Windage Tray 23020
Moroso Oil Main Cap Baffle 23000
Oil Pump Pickup/Screen
MSD Distributor 8571
MSD 6TN Control Box 6401
Custom built Moroso Yellow 8mm Spark Plug Wires with black boots
Edelbrock RPM AirGap Intake - Permastar Finish 7501
BG Speed Demon Carburetor w/mechanical secondaries 750CFM 1402010
McLeod Pressure Plate 12" 360820
McLeod Clutch Disc 12" 260873
McLeod throw-out Bearing 16010
McLeod Pilot Bearing (needle bearings) 8605
ARP Flywheel Bolts 100-2801
ARP Pressure Plate bolts
Percy's Reusable Carburetor Gasket Speed Demon 750 CFM Mechanical Secondaries 760-66021
ARP Carburetor S.S. ball-head studs, washers, &nuts Standard length 070-400-2401
Mr. Gasket Fuel Pump Mounting Plate 1514
Comp Cam Fuel Pump Push Rod Bronze Tip for Steel Mech Roller Cam 4607
MSD Blaster High Vibration Coil - mount in any position 121-8222
Felpro One Piece Oil Pan Gasket 375-1880
Moroso Oil Pump w/ pickup for 8 1/4" Oil Pan 22135
Edelbrock Fuel Pump 350-1721
Russel Dual Feed Carb Inlet w/ Inline Fuel filter 8AN Anodized 799-641280
Russell Fuel Pump to Carb inlet 8AN anodized components:
Adapter 3/8" to 8AN fitting Anodized 799-660480
90 degree Swivel 8AN Anodized Full flow Fitting 613170
Straight 8AN Anodized Full Flow Fitting 610030
3 feet S.S. Proflex Braided Hose 632100
Russell Assembly Lube 671570
Russell Gauge 15lb liquid filled w/black face & chrome case /white numerals 650330
ARP 12-point S.S. Engine Accessory Bolt Kit 070-534-9501
Moroso Aluminum Water Pump 3/4" Short Design for 71 Corvette 63505
Chrome 3/8" thread to 3/8" Straight Hose Barb for fuel pump 720-2965
Chrome 3/8" thread to 3/8" 90 degree Hose Barb for fuel pump
JEG's 8AN Wrench 80552
Mean Green Mini Starter - Offset bolt pattern, 168 tooth flywheel MG3520 - offset bolt pattern
ARP Oil Pump Intermediate Shaft 070-134-7901
Russell (8AN female/8AN male w/ 1/8" NPT port for gauge) 799-670350
Jeg's Oil pump prime rod 555-23640
ARP Damper Bolt w/ square drive 070-134-2503
Old Jun 10, 2005 | 08:55 PM
MsVetteMan's Avatar
MsVetteMan
Holy chit......you think you can be a bit more detailed.......
Old Jun 10, 2005 | 09:22 PM
Bullyj's Avatar
Bullyj
Not sure about price but looks like 5 digits to me
Old Jun 10, 2005 | 10:16 PM
b71vette's Avatar
b71vette
Default Details
Lot of time and research spent on developing parts list, thought I would save someone else the time.
Old Jun 11, 2005 | 10:14 AM
Roadster71's Avatar
Roadster71
Very detailed, what do you think everything cost and any estimate of HP & torque?
Old Jun 11, 2005 | 02:05 PM
b71vette's Avatar
b71vette
Default Cost around $7800, It Dynoed
at 489 HP and 495 Lb/Ft Torque, I was there when it was dynoed.
Old Jun 11, 2005 | 02:23 PM
SonnyMarrow
7th Gear
Wow! Thanks! Dang, that is as detailed as I'll ever need. I guess I start searching. I was expecting manufacture suggestions, but you gave me an entire setup! Thanks again.
Old Jun 11, 2005 | 07:01 PM
b71vette's Avatar
b71vette
Default SonnyMarrow - no problem
Glad I could help out. The balanced cast steel crank is good to 6500-7000 RPM. If you have the money you may want to go to a SCAT Forged crank.
Here is their website www.scatcrankshafts.com
Good Luck
Old Jun 11, 2005 | 08:12 PM
SonnyMarrow
7th Gear
I really appreciate this list. I have began looking up al the parts and they look great. I told my friend, who is a racing enthuseist, about the parts and he said it is better to not spend the money on the internally balanced crank, and get a 400 crank and change the harmonic balancer. I usually believe him because of all the great cars he has and has built, but this is iffy. He used a 400 crank, in his 400. From my understanding you have to mill away parts of the oil pan railings at the 7 & 8 cylinders for the 400 crank to clear the block, and the 350 crank, you don't, even though they offer the same stroke and CI increase. Any suggestions on this issue?
Old Jun 11, 2005 | 09:50 PM
b71vette's Avatar
b71vette
Default I'm no expert but I
think an internally balanced crank is the way to go. I believe you need more than just a different damper. believe you also need a special flywheel with counterweights for balancing.
I wish I knew a more technical means to explain this. It just makes sense to me that it would be better for the internal stresses of the crank,etc. if the crank was balanced internally vs. just at each end. I believe this would be even more critical for a performance engine.
I would go with the Scat 9000 series vs. a used OEM 400 crank though, it's stronger than the OEM, or at least that's what Scat states.
I spoke to Scat about the crank in my engine and they said due to it being internally balanced and the 9000 series metal that it was actually good to 600 HP and 8000 RPM but that is on the outer limits, I would go forged if I was going to rev it that high.
Old Jun 11, 2005 | 09:53 PM
LFZ's Avatar
LFZ
I have the Eagle cast crank and forged Rods internally balanced and spin to 6500rpm all day long. However, my AFRs and Victor Jr is where the power comes from.
Old Jun 11, 2005 | 10:33 PM
68/70Vette's Avatar
68/70Vette
The Vic Edelbrock "crate" engine signature series. It's a 383 cubic inch and it includes Vic's signature (engraved on the air cleaner). It's all hand built by Edelbrock employees, blueprinted, balanced, run on the dyno, etc. I've seen these engines at the Edelbrock plant here. I don't think you can really buy a better quality engine. (Unless you really get into the really exotic engine world.) There's several good quality engine builders. But the Vic Edelbrock signature series engine throws their very substantial engineering and manufacturing capability into this engine.
I watched one of their 350 cubic inch engines pump out 412 flywheel horsepower on a dyno. The engine was powering it's own water pump, so the output power was actually pretty realistic. I think that their engines seem at first glance apear to be a little expensive, but Vic Edelbrock is really dedicated to selling best quality products.
My opinion. I was one of a tour group lead through the Edelbrock facility by Vic himself. So, maybe I'm not impartial. Vic is a pretty impressive person. It's also impressive to see multi-millions dollars worth of robotic CNC machines automatically turning out aluminum heads, intake manifolds, water pumps. etc.
To Building a 383.
