engine run-on
Old Jun 11, 2005 | 03:04 AM
Turbo-Jet's Avatar
Turbo-Jet
Default engine run-on
hey-
just rebuilt my carb and i've had a few cases of run-on when i shut the engine off. it sputters very roughly for 1-2 seconds.
how harmful is this?
what are causes?
my timing was good and the engine ran fine before i redid the QJet. whatever the cause, it is right on the edge, as it only seems to run-on when the engine is very hot ie 200-210 after a heat soak from sitting for a few minutes and a short drive.
Old Jun 11, 2005 | 04:50 AM
comp's Avatar
comp
it is Hard on things,, is idle a little high
Old Jun 11, 2005 | 07:26 AM
Lasse's Avatar
Lasse
Not a big problem. Brake it with third gear and clutch.
Old Jun 11, 2005 | 07:37 AM
Ganey's Avatar
Ganey
Originally Posted by Turbo-Jet
hey-
just rebuilt my carb and i've had a few cases of run-on when i shut the engine off. ...
Since you just rebuilt the carb, probably high idle or lean. Did you adjust both idle & mixture?
Old Jun 11, 2005 | 07:55 AM
Matt Gruber's Avatar
Matt Gruber
it does sound like an inexperienced driver failing to release clutch in gear
Old Jun 11, 2005 | 08:14 AM
comp's Avatar
comp
To engine run-on
