Adjusting fast idle? [Quadrajet, pics]
So basically, I set the choke to full, crank the engine, it starts but it won't survive without giving extra gas, same thing happens with or without the choke after it has started.
I suspect the fast idle, since I have understood that the fast idle is "active" as long as the choke is on?
But, how do I rise the fast idle? I've read that the screw should be in the area around the choke linkage, but I can't find any.
Drivers side:
Passenger side:
(my solution for manual choke wasn't there when this pic was taken)
Could someone please describe how I rise the fast idle on a carbureator like this one? Or tell me another solution.
Thanks,
Christian
Thanks for the answer!
If there are any more opinions on this, please write
