due to the fact that i shaved my handles and locks and can't get my door poppers to work, i have one last option and that is to wire my alarm to roll my windows down so i can open it from inside...... now since i have a battery cutoff, i would have to run a wire to the power relay from the battery that would be alway on to operate my windows. my question is, what is the point of the window relay if i can just run power to the switches and tap the alarm relay/module to it...... i really don't understand why the power relay is there..... is it for amp reasons..... is it possible to bypass it..... or is the relay just for the ignition 12v power?
I replaced ALL my wiring with a "complete" painless wiring harness and there was no mention of a relay. If there was one required I feel they would have mentioned it like they did for the fan. I don't seem to have any trouble without relays. I still can't drive the car everyday or anything like that but testing the setup in the shop hasn't revealed any problems.
i think i'm just gonna take out the relay...actually mine is shot and am broke to buy a new one.......so, i'll try to bypass it and see what happens......the ponly thing that i see will be different is that the opposed to the power stopping at the relay, it will now stop at the switch....terms of connection.....
