I cant get a good Spark please HELP!
Old Jun 11, 2005 | 04:37 PM
2ndTIMECPL's Avatar
2ndTIMECPL
Cruising
Default I cant get a good Spark please HELP!
Please Help! stock H.E.I.
I have new
Cap, Rotor, Plugs, Coil, PIck up coil tested fine.
I get
power at the Distributor, grounded, and 1 maybe 2 sparks and thats it.
Is there something I am over looking. I dont know a way of testing the module but i suspect its fine it along with the distributor came out of a running engine.
I have a stock 350 1981 engine the distributor is an HEI with only four leads at the module if that helps. I am not considering the ECM because i dont see where they are communicating or is that my problem
Old Jun 11, 2005 | 04:56 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
do you have power at the plug? if you do, i would suggest checking the connectors at the dist.. they can be a pain to get right...
Old Jun 11, 2005 | 06:00 PM
Boofers's Avatar
Boofers
Check your engine ground cable???
Old Jun 11, 2005 | 10:11 PM
2ndTIMECPL's Avatar
2ndTIMECPL
Cruising
Default power at the plug?
How do i check for that Do you mean Can i get a spark to jump.?
I managed to get it to do it once. and thats it on a couple tryies.
I will detach and resecure the engine ground cable tonite.
Thank you guys any other suggestions are more than welcomed at this point i am completely stummped. Thanks again.
Old Jun 12, 2005 | 05:22 PM
page454's Avatar
page454
Sounds like a bad ignition module to me, problems can be very erratic and intermittent. Usually when I have a hei distributor problem, I buy both a coil and module, fixes the problem every time. Good Luck.
Old Jun 12, 2005 | 05:27 PM
2ndTIMECPL's Avatar
2ndTIMECPL
Cruising
Default is there a module test?
Is there any way to check that module because once you buy it there is no taking it back. I baught the whole bottom half of the didtributor and I would hat to think it came with a bad module.
Thanks for all the advice.
will
Old Jun 13, 2005 | 12:06 AM
Todd68's Avatar
Todd68
will
You've got mail.
Old Jun 13, 2005 | 07:20 PM
2ndTIMECPL's Avatar
2ndTIMECPL
Cruising
Default cant find your email
I did not recieve your email can you shoot it to me again please. I am on the edge of my sanity trying to figure out my spark problem and any and all advice is greatly appreciated and respected.
thanks again
will
Old Jun 13, 2005 | 10:57 PM
Todd68's Avatar
Todd68
Just tried sending the info. Had some email issues. Hopefully it goes through this time - sholud be five pages all together. Let me know if it all gets there.
Todd
Old Jun 13, 2005 | 11:15 PM
Rich80's Avatar
Rich80
Well if you do get an ignition module, Pep Boys charges about 20.00 bucks for one and Napa auto parts is about 35.00... I always keep one as a backup. Let us know how you do....
To I cant get a good Spark please HELP!
