Intake sealing problem
I have AFR 195 heads, a Weiand Action plus intake, and I am using Fel Pro #1205 gaskets.
When I initially assembled the engine, other than the RTV on the water ports and end walls I did not use any sealer on the on the intake gaskets, and I torqued the bolts in the proper sequence.
The black soot coming from the exhaust told me that something was wrong, and the tiny bit of oil pooling on the gasket between the intake and the head gave me a good idea of where to look for the problem.
I replaced the gaskets, but this time I used a thin coat of Permatex #2 around all the intake runners between the gasket and the head (no sealer on the intake side).
It seemed to seal for a short time, but I was soon seeing more black soot and recently started seeing oil seepage at the gaskets again.
From the pics you can clearly see that there is oil seeping past the gaskets, and although they are a little blurry you can see some buildup on top of several of the intake valves.
The #5 valve has the worst buildup on it.
It appears that the gaskets are compressing a little more at the top than at the bottom, so I might need to have the intake milled in order to get it to seal.
Is there an easy way to determine the angle and amount to have the intake machined?
Does anyone have any good tips for getting a stubborn intake to seal properly?
Any and all advise is appreciated.
or...
If the block was decked this has the same effect.
There was another post about this same problem recently and there is a formula for the amount to remove from the intake.
Sorry I don't have a link for that on hand right now.
KC
or...
and I didn't have a practical way to measure it when I started assembly.
Is it OK to use RTV on the intake runners too, or should I try some other type of sealer like the spray on copper stuff?
Sometimes, it seems we outsmart ourselves buying the fancy stuff...
The angle difference between manifold and heads can be off by as much as 5°. On a 2.75" tall Intake flange, this would create a .025" mismatch from top to bottom, and create less load required for sealing at one end.
Intake leaks seem to be more of an issue when combining different manufactured parts together that are "supposed to fit". Different manufactures have different tolerences, and the "stack up" of these variances effect sealing. So basically the "height" and "angle" between the Heads and Intake needs to be checked for correct sealing.
Hope this helps,
Later.
Sorry to hear about the problems. Did you actually have oil visible between the head and intake from the top?
Any idea on what your going to do? You might want to call DES and see what they think or if they have a recommendation.
Tim
Tim
The gaskets were oil soaked on both sides, and there is a little oil buildup on top of the intake valves (some worse than others).
I used no sealer on them during the initial assembly, and Permatex #2 the last time I put it together. It sealed a little better last time, but the Permatex had obviously hardened and allowed the leaks to re-emerge. I think I have decided not to cut the manifold at this point, but I will use RTV when I assemble it and I might use different gaskets. Hopefully it will solve the problem.
I have a few days before my transmission get back from the rebuild to decide, so I will be calling several different sources for more suggestions.
Need to change my profile name to Ex-GasketDude! As they've been doing head count cuts in June and I just got my walking papers yesterday (6/13) after 15 yrs. At least I'll get more time on the Jet-Ski with my 7yr old this summer
Anyway, borrow, scam, or buy this gauge. Split the cost with a buddy or have your local club buy it for future use. I don't know the cost off hand (as I got my back when it was a future release) but they will save you headaches in the long run. Maybe the local machineshop will let you borrow theirs for the night? Knowing you'll be bringing your manifold in for machining.
The more I read these Intake leak issues the more it makes me think about writing a paper and posting it here or on the other forum for those to read and download. All the sealing "rules" apply no matter who's gasket you use. And I see the same mistakes being made here, repeatedly.
Oh yeah, don't dis the gaskets if its a hardware issue on your end
.Good Luck,
(sorry for the rant)
Later.
G.D sorry to hear of the job problem. I know it doesn't help but that happening all over the country these days but not much is being said or done about it.
I would sure like to read your paper if you write it.
Good Luck,
Gary
My combination: OEM L48 block (no decking as far as I know), DART Iron Eagle 180cc heads, Edelbrock Performer Intake (3701).
Noticable changes so far: quieter on top side of engine. I suspected some leakage that contributed to what I thought was valvetrain noise. Still some noise but quieter...
After thouroughly cleaning all the gasket surfaces I checked the fit of the intake to the heads using my Mark1 eyeball, and a set of feeler gauges. It appears that the intake fit slightly tighter at the top than the bottom (0.005" or so) but I don't think that is enough to make that much of a difference.
While I was looking though I noticed that several of the bolt holes in the intake had impressions of the bolt threads on the top side. It appears that the bolts had been supporting the intake and preventing it from being squeezed down far enough onto the heads.
I went after all the bolt holes with the die grinder and opened them up enough so that I could easily thread all the bolts though the intake into the heads even without a gasket in place (just to be sure that there would be no problems once the gaskets were installed).
Since the permatex #2 didn't appear to work worth a flip the last time I opted for RTV (Utra Grey) on both sides of the entire gasket this time, and also used the same RTV on the bolts instead of the permatex.
It started right up and once I got the timing back where it is supposed to be it ran much smoother than it did a week ago. The manifold vacuum is up 2" from where it was, so I feel pretty certain that the intake is sealed now. Only time and miles will tell if I have solved the problem for good but I am very hopeful. I am going to work on tuning the carb again tomorrow, maybe a have more of a fighting chance now that it the mixture is not being screwed up with all that oil mist getting into the cylinders.
Oh yah, It sure is nice to have a transmission that shifts properly now too!!!!
I did search the forum archives before posting this though and I recall seeing at least one thread where the guy was getting oil pooling in the intake under the carb and he suspected that it was coming from the intake gaskets.
