Spal part numbers? Dual 11" fans?
Former Vendor
Originally Posted by Gordonm
Can you tell us more about this module. Does it just tie into the sending unit wire and tell the module when to turn the fans on/off. What is the cost. I did not see it on the website.
Former Vendor
Originally Posted by SanDiegoPaul
Tom, you quoted me $395.00!
Originally Posted by Tom DeWitt
It's not on there yet but it's part number PWM and it cost $65. The module can control one fan all by itself, which means it has a built in relay. You tap off the stock temp sending unit and run this into the control. It uses the analog signal to sense temperature and you set the on/off points. If you have two fans (ie duals spals) then you have to purchase one additional relay/harness ($31) and that's it. What's the best feature of this thing is you don't have to find a place to install a switch!
That's right, and if you read a couple posted above I said "this is for the fans only" not the complete kit which is $395
Brett
Do you have any documents available yet we can download or look at? Also, would you tell us how this new module (PWM) can be incorporated into one of your previous Dual Spal / Dual relay setups (that I STILL haven't insstalled in my car yet!!)?
Thanks,
Paul
Originally Posted by pws69
Tom,
Thanks,
Paul
Thanks,
Paul
