Entropytec radiator??
Entropy eBay
My only beef was no PayPal or personal checks. Had to trudge down to the post office and buy a money order. Shipped promptly, packaged well. Highly recommend.
Do an E-Bay search on Zirgo. You'll see a million of 'em.
I fitted one of these during the winter to my 1974 350 Auto.
When I got the old one out I found I needed a new frame too (I think that came from Ecklers), but the RAD came from Entropy.
Fit:
The top of the RAD (plate screwed to the RAD block) needed a little material taken off it (about .25 inch at each end) to let the stock clamps fit properly.
The Fan shroud also needed a little material removed since the ports were not quite at the same angle as the old brass RAD.
Since mine is an Auto, it had the oil cooler in it. The new Oil cooler element was not quite in the same position (no problem) and is a bit bigger than stock (no bad thing).
The old RAD cap didn't fit (The keyway was too small) - but a new one (local auto shop) fitted fine???
So all of these things were easily solvable...... BUT.....
The position of the drain plug on the original was under the RAD on the passenger side - however on the new one it is bottom left on the back face and hence it fouls on the chasis. Made me swear a LOT - I only found this after fitting it to the new fame and installing it (well nearly installing it).
Solution : Cut a small amount out of the chasis and replace the tap (would have been useful) with the original plug - which is shorter than the tap.
Basically then it's fine - but there is a lot of 'hand fettling'. I still have the problem that when I next want to drain the RAD I'm going to have to lossen lots of things so that I can remove the plug!!!!!!! AAArhhhhhh.
Customer Service:
Great before sales / great price / great packaging.
However when I started to ask questions about the fan shroud not quite fitting and the blasted tap thing, oh yes and the old RAD cap not fitting - the e-mails stopped.
Since all the things were easily solvable and trying to throttle somebody overseas is not always easy
- I made the best of it.If you are happy to struggle through a little bit then this RAD (performance and price) is great.
If you want EASY installation - go somewhere else.
My opinion only.
Any more questions please ask...........
Jeremy.
My draincock, however, was in the correct location (lower pass. side).
I did not have to worry about fitment of the shroud as the combination aluminum rad & elec. fan made the shroud unecessary.
If you have an auto, the cooler fittings need to be changed to FIP fittings. I used translucent plastic fittings (Zytel?) from a boat. I can see the tranny fluid flowing thru 'em.
Mine wasn't overheating - I changed it because of a leak between the side tank and the core it had already been recored many years ago and I didn't want to do it again.
J.
J.
