Urethane trans mount: your thoughts?
Old Jun 16, 2005 | 11:23 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Urethane trans mount: your thoughts?
My old mount is almost toast, so this is more of a two part question.
A) Is the urethane mount worth it? Do I need to run different motor mounts too?
B) Should I use the old mount until the urethane one gets here? The old one is, well, old and I'm not sure how that would affect the car.
Old Jun 16, 2005 | 11:33 AM
CGGorman's Avatar
CGGorman
I've always heard that the trans mount should be equivalent stiffness to the engine mount. If the two must be different, then the trans mount should be the softer of two.
Is it worth it? Probably not, but that's what I've got! Went with poly engine mounts for less flex, so I figured I'd match the tranny mount.
I've also heard that the Energy poly tranny mount is too thick. I used a Prothane tranny mount and Energy engine mounts. No issues for me...
Old Jun 16, 2005 | 11:35 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I thought I remember reading here awhile ago that the poly tranny mounts were not good to use b/c they were a different hieght than the stock rubber. Had something to do with the poly mount throwing the angle of tranny off and causing vibrations. Could be wrong though.
Old Jun 16, 2005 | 12:14 PM
Mike Ward's Avatar
Mike Ward
I've always wondered why people would want a poly mount in ANY location- body or engine or transmission.
These mounts are made of rubber specifically to isolate vibration. Why would anybody want to defeat that function is beyond me.
There is no 'performance upgrade' factor involved, despite what speed vision TV says.
Old Jun 16, 2005 | 12:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
When you order a tranny from Keisler it comes with the stock GM mount, I too don't see any reason to go away from rubber.
Old Jun 16, 2005 | 12:20 PM
rihwoods's Avatar
rihwoods
That is right.All it takes is about 3 degrees.....from norm......
Old Jun 16, 2005 | 01:51 PM
Boofers's Avatar
Boofers
How about causing your bellhousing to crack. I changed my clutch last month and found 2 big ole cracks in the bellhousing (no these cracks were not just casting marks). The engine builder I got my replacement bellhousing from said the most likely cause is a worn tranny mount. I replaced my stock hollow mount with a solid rubber one for like 6 bucks.
Old Jun 16, 2005 | 03:08 PM
Buffalo Dude
St. Jude Donor '07
I think I'll just run to Kragen and get one. Looks like it's in stock for ~$7.
I get the impression that urethane isn't really worth it unless going for the whole setup, so I'll stick with rubber.
To Urethane trans mount: your thoughts?
