why are my newly installed u-joints binding?
So then I moved on to the drive shaft. I installed u-joints on each end and they too require a lot of pressure to move back and forth. This is not the result of a needle falling into the cap. The cap will not seat properly if a needle has fallen to the bottom and you can't get the clips in.
As suggested it could be that the yokes on both ends of the drive shaft as well as the one half shaft I worked on are bent just a little. I'm also suspect of the grease loading up on the opposite side from which I was hammering.
I think there is a drive shaft shop nearby that is not too expensive. I may just take it there and be done with it. Sometimes my trying to save a few bucks delays my repairs longer than necessary in the name of doing it myself. I really want to get back on the road. It was breezy and 75 degree here today... great convertible driving weather. I also just received my C5 seats that I want to get installed.
This method solved all my warranty claims over the years with my truck. Where a universal lasted 13 month regularly I got 5 years with this method and sold the truck.
My vet universals are about 14 years old and never had a problem.
I have a very accurate press and have seen joints take up to 12,000 pounds. That has got to bend something.
I use an arbor press. But whatever you do, try not to heat the yokes up when using the torch. That could warp the yokes or even allow them to bend easier when dismantling. Cutting out the Xs with a torch is not a bad idea. But if you use an arbor press properly, everything is supported properly and will not cause anything to bend out of proportion. I also want to stress the "cleanliness theory". You need to clean the surfaces slightly in order to ease in the installation of the new U joints. But make sure that you do not oversand or overgrind on the surfaces. Otherwise you might render the U joint useless by allowing for too much play in the machined surfaces. I have done literally thousands of U joints in the many cars and trucks that I have worked on in the last thirty some years. I have never had one come back due to failure from an improper installation. If a U joint is installed properly, it should not have any binding at all no matter how much grease you pump in to it.
