Timing chain/gears, help with removal/install
Old Jun 18, 2005 | 03:42 PM
Star79's Avatar
Star79
Default Timing chain/gears, help with removal/install
Okay I DEFINITELY needed a new chain/gears. Here is the play in my old ones:
Since they are so loose, I can't tell if they are aligned right or have slipped/jumped. I had the balancer at TDC before I pulled it. My rotor is pointing between #8 and #4. The crank keyway is right now approx 5 o'clock. I haven't pulled the vc's to see if the valves are closed on #1. If you look at this picture (hi-res, too big to insert into thread)
http://pages.infinit.net/weevie/timing.jpg
can you tell if the crank and/or the cam is in the right place? I've never done this before, and I don't know where the "marks" are supposed to be on the gears. In my manual they are OBVIOUS (white painted dots...) but I see nothing quite so obvious on my car.
Did my balancer slip? Did my timing chain jump?
Oh, the car was running before I took it apart
TIA for any help.
-steve
Old Jun 18, 2005 | 04:13 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if i am thinking right, align the dots up as close as you can and then pull the chain. then pull the chain and gear. when you put them on, realign the dots and you should be good to go...
Old Jun 18, 2005 | 04:24 PM
Star79's Avatar
Star79
Which "dots" though? On the crank gear I see a dot (right now near 3 o'clock, you can see it in the picture linked above. I thought that one was supposed to be straight up at TDC, that's what has me thinking something's off) but see no such markings on the cam gear.
Old Jun 18, 2005 | 04:41 PM
tigers123's Avatar
tigers123
Default alignment
Put motor on top dead center number one cylinder and see where dots are. Should be in alignment. Buy a double roller timing chain and gearset.
Old Jun 18, 2005 | 04:42 PM
henderjl's Avatar
henderjl
Default What, Me Worry?
Why are you so concerned about it. You will be able to see the dots on the new timing set. Put them on and line them up! There is an adapter that you can buy to make it easier to turn the crank without a bolt in it.
Old Jun 18, 2005 | 05:42 PM
ltlevil's Avatar
ltlevil
That's all you gotta do. Don't worry about valves hitting pistons or anything like that if that's what you're worried about. When you get the new set the timing gear mark will be at 6o'clock and crank gear at 12o'clock. Can't mess it up.
Old Jun 19, 2005 | 01:19 AM
Star79's Avatar
Star79
I'm not worried I'll mess it up...I'm worried it's already messed up, or at least wondering what exactly is messed up. Remember my balancer was set RIGHT ON TDC, then I got it apart and the marks were as pictured below and my rotor was between 8 and 4. I'm assuming the arrow circled is the mark on the cam gear (I can't find anything else that looks like a "mark") If I turn the whole deal CCW until the crank gear mark is at 12:00, the pointer will also be at 12:00, the rotor will be nearer the #1 plugwire. That sounds like where everything should be, but then if I put the balancer back on it will be about 23 degrees AWAY from tdc.
Can anyone confirm that these marks are what I say they are? Is my balancer the only thing screwed up? I'm only concerned cause the first (and only) time I ever changed a timing set I could never get the car to run properly (340 Challenger about 20 years ago...)
Old Jun 19, 2005 | 01:29 AM
ltlevil's Avatar
ltlevil
Thats not the mark look closely around 5'oclock on the cam gear I think I see the same dot like on the gear. Another thing is don'y go entirely by the balancer. It's quite possible the ring has slipped. If what I see is the mark on the cam gear when you turn the crank gear to 12 o'clock the will be close to lining up. Go ahead and turn the crank dot to 12 oclock and look at the cam gear top and bottom and I think you will see your dot. Let me know.
Old Jun 19, 2005 | 01:40 AM
ltlevil's Avatar
ltlevil
sorry had the pic flipped look at ten oclock on the cam gear there is your mark. You'll have to turn the motore a little more than a full turn. I am sure when you do this you will see your mark.
If you pm me I'll send you a marked up pic.
Old Jun 20, 2005 | 02:16 PM
stingr69's Avatar
stingr69
The keyway should be pointing to the drivers side deck surface when the crank is at #1 and #6 TDC position. If yours was in that position, you would be fine. Looking at the pix it appears that you are not there. Rotate the crank to that position and check the dots and damper position again.
-Mark.
Old Jun 20, 2005 | 04:19 PM
Star79's Avatar
Star79
I think I got it, thanks to the above replies. Steve the mark you emailed me wasn't a "dot", it was an oil smudge
I turned it over till the crank dot was at 12:00, the keyway was about 1:30 (driver's side deck surface as noted above, and agreed with my timing chain install instructions), rotor was very near #1, cam sprocket was very close (not exactly due to chain looseness) to having the "pointer" right at 12:00 and the dowel at 9:00 (again agreeing with instructions). Now it's back together, very nice and tight with a Cloyes dbl roller, dots lined up (both at 12:00, pics later, forgot my cam at home) and the only thing messed up will be the balancer when I put it back on, it must have slipped about a quarter turn. Is that possible and /or normal?
Old Jun 21, 2005 | 08:27 AM
stingr69's Avatar
stingr69
If you have the dots lined up and the timing cover on with the damper installed they should all line up. If not, the balancer ring might have slipped.
Keep in mind that with the dots "together" the engine is in the #6 TDC FIRING position. #6 and #1 pistons will both be at TDC but the cam is ready to fire only one of those cylinders and it is NOT #1! it is #6.
-Mark.
Old Jun 21, 2005 | 10:52 AM
flood's Avatar
flood
I see you have that awsome original cam gear with the nylon teeth! When I did mine I couldn't figure out why they would have done that? Wouldnt it have been less expensive to just make the entire gear out of metal?
Old Jun 21, 2005 | 11:07 AM
Star79's Avatar
Star79
Lighter and quieter I believe was the reason. Forget about durability and longevity!
To Timing chain/gears, help with removal/install
