69 gear ratio?
Old Jun 19, 2005 | 08:33 PM
FD2BLK's Avatar
FD2BLK
Default 69 gear ratio?
My father in law just bought a 69 vert and he hates the fact it turns so many RPMs while crusing. He is running over 3000 around 65-70MPH, my question is can some one help me with the rear end ratio? I don't know if the rear gear is stock or not but before I order a new gear it would be good if I can find about what ratio he currently has. I was thinking of a 3:08 should put him where he wants to be but any help would be great. The car is an 350 4 speed with the close ratio trany and has had some work such as a cam that we have the spec card on but I didn't find a reciept for any rear end work. Thanks in advance for any help you can provide.
Old Jun 20, 2005 | 12:05 AM
Simmo's Avatar
Simmo
A 350 with a bit of a cam and a close ratio box (2.20 first) isnt going to like a 3.08 gear around town. A fifth gear would help.
Old Jun 20, 2005 | 12:23 AM
early shark's Avatar
early shark
If the tires are close to stock height ( around 27 inches tall), more than likely the rear axle ratio is 3:70.
With a M21 transmission, you would be better off with 3:36 ratio as your minimum. If you changed to a M20 wide ratio transmission, 3:08 ratio would be fine.
To 69 gear ratio?
