Wipers wont work
Old Jun 19, 2005 | 10:36 PM
lester69's Avatar
lester69
Cruising
Default Wipers wont work
I was trying to clean up some wires along the firewall , now the wipers won't work , door opens but nothing , how can I check if the motor is ok and what are the vacuum lines for connected to the motor.
Old Jun 19, 2005 | 10:44 PM
Jack71's Avatar
Jack71
Pretty sure those vacuum lines are fluid lines.
Did you check the connections? There is also a ground wire attached there too. Does your heater fan work? (I think they are on the same circuit)
Old Jun 20, 2005 | 03:15 PM
CGGorman's Avatar
CGGorman
There should be a diagnostic procedure in the chassis/haynes/chiltons manual. I can't remember if the power connector is a simple two-wire hookup or if it's more complex to attain two speeds... Did you put a voltmeter on the harness-side connector?
To Wipers wont work
