Bleeding rear brakes
Old Jun 20, 2005 | 10:29 AM
pennor's Avatar
pennor
1st Gear
Default Bleeding rear brakes
OK, I'm stuck, and it's not like I haven't done this before because I replaced my calipers with stainless ones, drained the brake lines and converted to DOT-5 fluid about 14 years ago. Here's my problem...
I had to have bearing work done and in the process of removing the old caliper steel brake line I broke it and had to replace it. After reassembling everything I went about bleeding the rear brakes. First I used the bleeding bottle with my wife pumping the brakes. This always worked for me in the past. The fluid ran clear with no bubbles but the brakes were still soft and the brake lite came on when braking. Next I bought a vacuum bleeder and used it with the same result. I've run a quart of new DOT-5 fluid through those brakes and they are still soft and the brake lite is still coming on during moderate of harder braking. I'm at my wit's end!
Anybody got any ideas?
Old Jun 20, 2005 | 12:41 PM
viperjesse's Avatar
viperjesse
Bleed all the brakes. Air may have migrated up in the lines. Be sure NOT to let the resevoir go empty while bleeding or you'll have to start all over again.
Good luck
JZ
P.S. Be sure to bleed BOTH bleeders on the calipers, there are 2 on each.
Old Jun 20, 2005 | 04:05 PM
Tom454's Avatar
Tom454
Your brake switch has -probably- slipped off to one side while you were bleeding it originally. If so, it needs to be kept centered before you can bleed.
Close all 4 bleeders and stand on the brakes hard several times.
Hopefully the light will stop coming on when you press the pedal.
If not, it is "moved" to one side. I use -dried- (4 separators) compressed air blowing backwards through an open bleeder of the non-bleedable circuit to force the switch piston back on center. The cover has to be off the master cylinder and a rag thrown over it. If you do this, only give the line a few quick shots of air until the switch resets. Don't blow air back through the master cylinder.
When you do get the switch centered (light stays off), bleed one rear & one front at the same time to avoid the switch issue again.
This may not be your problem.... but it is a good candidate.
Old Jun 20, 2005 | 05:15 PM
onaqwst's Avatar
onaqwst
gravity........ i did it on all mine and my brakes stop on a dime....... one caliper at a time
b
Old Jun 20, 2005 | 07:06 PM
71SoCal's Avatar
71SoCal
The Haynes manual says that the brakes should be bled left rear, right rear, left front, right front. I would have guessed right sides first, but that's what my manual says.
Good luck...
Old Jun 20, 2005 | 07:17 PM
iNdigo's Avatar
iNdigo
I always thought you should bleed the farthest caliper from the master cylinder first... i.e. right rear, left rear, right front, left front.
also try tapping the calipers and lines with a wrench to encourage bubbles to "keep-a-movin"
tbw
Old Jun 20, 2005 | 08:20 PM
lvjohn's Avatar
lvjohn
I had a similiar problem with my 71 corvette ended up that the the rod coming out of the brake booster was not adjusted the correct length. Good luck hope you get it fixed soon sucks to have spongy brakes.
Old Jun 21, 2005 | 07:53 AM
Tom454's Avatar
Tom454
Default Order is irrelevant
I know the manual and the "old" school says "furthest to closest" but...
Based on "hands on", in the field, real world testing, the order of bleeding has no effect on how good a job you do. I tested this a few years ago for Forum members to settle a debate. I bled one of my Vettes in several different orders, each time removing the fluid from all of the lines & calipers with compressed air. Order had no effect. If you fully understand the function of the hydraulic system, you can bleed your Vette in any order, as long as the M/C is done first.
So... don't get hung up on "order".
I still follow "furthest to closest" just as a matter of habit.
But it ain't no big thing.
Old Jun 21, 2005 | 08:24 AM
pws69's Avatar
pws69
Get yourself a pressure bleeder and be done with the misery!!
Old Jun 21, 2005 | 12:36 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
It's GOTTA be 1,2,3,4. No wait....2,4,1,3....no....3,4,2,1...nooo. .1,4,3,2.
4,3,2,1 PRESSURE BLEED!!!
Dep
Old Jun 21, 2005 | 03:47 PM
NHvette's Avatar
NHvette
I gravity bled mine - then they worked but very spongy.
After a few days, I rapped on all the calipers with my rubber
dead-blown hammer to loosen any stuck air bubbles.
Then, I had my son push the pedal while I cracked each bleeder.
Now, they are solid as granite. I bet you have trapped air bubbles.
Note - don't "pump up" the pedal before cracking the bleeder,
as this only aerates the fluid with micro-bubbles of air that then
travel into the tubes and stay there.
Old Jun 21, 2005 | 04:33 PM
wnjlt1's Avatar
wnjlt1
w/Tom454
Old Jun 21, 2005 | 04:51 PM
redvetracr's Avatar
redvetracr
tbw
BUT use a rubber hammer!!
Old Jun 22, 2005 | 03:33 PM
WrenchingIt's Avatar
WrenchingIt
Default The Answer
Swear to God the worst time I have had with my C3 is bleeding the brakes. The answer? Buy a pressure bleeded, they are like 40 bucks. Best money I spent!
Old Jun 22, 2005 | 03:42 PM
DJ Dep's Avatar
DJ Dep
Tom454 will jump on you for that post, but you're right
Dep
Old Jun 23, 2005 | 07:35 AM
Tom454's Avatar
Tom454
Dep
I only jump on women. The guys I hump.
Old Jun 23, 2005 | 08:17 AM
DJ Dep's Avatar
DJ Dep
HA!
Old Jun 23, 2005 | 09:44 AM
GDaina's Avatar
GDaina
I thought humpin' and jumpin' meant the same thing...
To reiterate what's been said above, I made my own pressure adapter, got the DOT 5 moving on all 4 calipers, then used gravity and a 4LB dead blow hammer...the bleeding order? Doesn't make any difference, remember, the front and rears are on seperate lines.
To Bleeding rear brakes
