E-brake adjustment
Old Jun 20, 2005 | 02:17 PM
rogerdavid's Avatar
rogerdavid
6th Gear
Default E-brake adjustment
Recently, I have tried to adjust the e-brake on my '82 vette. I have followed my corvette repair manual's instruction. I ajusted the star nuts in the rear hubs until they locked up and then released them 6 notches. I then adjusted the center equalizer until the lines were sung. I have adjusted them several times and I still can't get them to work properly when I pull the ratchet from inside the car. Any advice!
-Dave
Old Jun 20, 2005 | 02:27 PM
pws69's Avatar
pws69
-Dave
The E-Brakes on our cars suck!!
Having said that, you MUST release ALL tension from the cables (under the car - just follow the cables from the wheels toward the Handle and you will run into the cable adjuster) BEFORE you adjust the star adjusters. Then adjust the cable.
Old Jun 20, 2005 | 02:54 PM
rogerdavid's Avatar
rogerdavid
6th Gear
Thanks, I'll try that right now and let you know in about a half hour how it turns out!!!
To E-brake adjustment
