Suspension input - 77 L48, 9 Leaf
Old Jun 21, 2005 | 12:06 AM
C3nMe's Avatar
C3nMe
Default Suspension input - 77 L48, 9 Leaf
I've been spending some serious time under my 77 C3, and I wanted some input on the suspension. I can tell the shocks looks majorly rusted, and the bushings are all decomposing that it's time.
The system is pretty light, from what I've read. I have a 9 leaf spring in the rear, and no rear antiroll bar.
Now, here's my driving style: I don't tend to baby a car, even one like this. I will lean on it in the corners and today the body roll is noticeable. In fact, it is so bad that I feel like the car has major oversteer.
So, what parts should I look at? I have seen on ecklers they have a number of packages to upgrade the whole deal. I think the poly bushings is a good idea, I know I need new shocks, but don't know what was there before. The leaf spring isn't broken, but the bottom spring is twisted from the rest -- figured I'd replace it.
I've seen Bilstein appears to be respected, but is that overkill for my L48? Do I add the rear antiroll bar? I am not going to drag race or road-coarse it ...but I'm always faster than the others around me in the turns.
The more I read, the more I'm not sure what's right for my use.
Thanks in advance for any input....
Brian.
Old Jun 21, 2005 | 12:53 AM
CrossedFlags77's Avatar
CrossedFlags77
Get new shocks and also replace all your bushings with poly bushings. Replacing those 30 year old bushings will make a huge difference as will new shocks. Once you do this see how you like the ride/performance and then look into aftermarket springs and sway bars.
Old Jun 21, 2005 | 05:37 AM
fl_rider's Avatar
fl_rider
Default Aword of warning...
I ordered the 9 leaf 2-1/2" spring from Mid America and:
1. It was "Made in Malaysia"
2. It raised the rear of the car up so high I had to install 8" bolts from Caterpillar to settle it back down.
Other guys have posted here that the VB&P springs are correct. NOW I know that...
My car does ride and handle remarkably better now. It just took some extra effort and expense.
Chris B
Old Jun 21, 2005 | 07:25 AM
C3nMe's Avatar
C3nMe
Is the Bilstein shocks worth it, or are the Monroe or KYB that I hear mentioned from time to time adequate?
I certainly am not trying to get this to ride soft like mom's station wagon or mini-van. I'm expecting that the suspension should be a little stiffer to handle the performance that I hope it will again be capable of.
Old Jun 21, 2005 | 07:38 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Definately start with all the bushings, some say poly squeeks, some they they don't, mine are fine..... it's a little harsher than rubber I assume but my rubber bushings were so worn that I cannot tell what exactly made more of a difference: the material or the simple fact that the bushings now fit properly....
Now look at springs - the 9-leaf that I have was re-arched at some time in the past. Now I need 9" bolts to get the ride height down to where it should be. A 7-leaf is stiffer, those from VBP have good feedback here on the forum (quality and ride height).
The Bilstein shocks are worth every penny, especially with the 550lbs front springs.
The 460lbs springs raise the front by 1.5" - 2" .... there are several threads on that subject, do a search.
Old Jun 21, 2005 | 09:08 AM
NHvette's Avatar
NHvette
Just grease the poop outta the poly bushings, and they will not squeak.
IMO - the adjustable strut rods are the way to go (VB&P).
The Bilsteins are nice - no doubt. However, with a steel spring the KYBs should be fine.
The need for a rear sway bar will be argued ad-nauseum.
IF you decide to put a rear bar on - make sure it is MATCHED to the size of the front bar.
Test drive in a big empty parking lot before taking any corners at high speeds.
I just finished bolting up the front/rear bar set from ZIP ... 1 1/8" in front
and 3/4" in the rear. I debated over and over in my head - whether
to install the rear or not. I will try it on for now ... test drive in July.
It is a pretty nice set with all hardware and poly bushings/end links.
Note that it is not the original (rear) style - which is a better (hinged) design.
Aftermarket rear bars use an end link like the front - into a plate bolted to the trailing arm.
BTW - my front coils are 460 lb/in Spicer #5851174, and they
installed normally to give an 'off the shelf' fender lip height of
27 inches. No coil cutting here - yet.
... got 'em at my local parts store for under $50.
Old Jun 21, 2005 | 09:28 AM
73 Vet's Avatar
73 Vet
Oh crap! I just ordered the 460# springs from VBP. Are you saying I'll have to cut them? How much do you think?
Old Jun 21, 2005 | 09:49 AM
Boofers's Avatar
Boofers
I am in the same boat as you. I bought Van Steel's 1963-1982 suspension video to help me learn about my suspension. The video is well done. I can't wait until the fall when I can tear my car apart.
Van Steel Suspension Video
Old Jun 21, 2005 | 12:55 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You'll have to cut at least 3/4 coil to get to 27". Mine was at 29.25" or so when I had those.... I bought the 550s and now it's at 27" and some change.... they are definately not harsh with the Bilstein shocks. The KYBs don't have enough rebound dampening to control this heavy spring, that's why it will be bouncy and harsh - you will be riding on the spring with insufficient dampening.
the KYBs are fine for the rear with the 9 leaf spring but the good deal on Bilsteins is only on a set of four ($250)...
I'd call VBP and change the order to the 550s...
Old Jun 21, 2005 | 01:02 PM
73 Vet's Avatar
73 Vet
Here's a quote from MassVette on 6/18: I used the 460# GT springs from Vette Brakes & Products. They lowered the car about 2" in the front.
According to Jeff at VBP, the 460's are supposed to provide "original" spec ride-hight.
Old Jun 21, 2005 | 01:12 PM
zymurgist's Avatar
zymurgist
I have a '77 L48, but my car started with the FE7 suspension (7 leaf rear spring, rear sway bar). The factory rear sway bar is a little bitty 7/16" unit... most aftermarket rear bars are bigger than that. As a previous poster said, make sure that the rear bar is matched to the front bar. Front bar is 1 1/16" if I remember correctly.
Springs: I went with the 550's up front and a 355 glass spring in the rear (Muskegon Brake).
Bushings: I went with rubber on the A-arms and T-arms, and poly everywhere else. They came with grease and I used plenty of grease on installation and they do not squeak.
Shocks: Konis set on full soft (as soft as they get).
I have a VERY nice riding car that makes no excuses when I want to tackle the twisties. I also have a 1970 Porsche 911 that is set up for track use, and the suspension in the 911 is so hard that it hurts to ride in that car for more than an hour; by comparison, I can comfortably drive the Vette all day with my setup.
Old Jun 21, 2005 | 01:42 PM
rihwoods's Avatar
rihwoods
Whatever you install back there,new spring/shocks/squeaky poly bushings,etc,go get a four wheel alignment done afterwards....and take it to someone who knows how to shim a Vette.Recommend you look at "advanced"street alignment set-up which is not to radical...there is suggestions for "stock","advanced street" and "autocross" on one of these Vendor (suspension) sites.(can't remember)..."Autocross" set up not recommended for street BTW...
Old Jun 21, 2005 | 02:01 PM
twistdpair's Avatar
twistdpair
Anyone ever try the Eckler's Max Performance package?
http://www.ecklers.com/product.asp?d...QM55X250R5ASWA
I assume that everything is matched pretty well. It seems like it might make things easier...
Old Jun 21, 2005 | 02:35 PM
C3nMe's Avatar
C3nMe
I have done a fair amount of looking at the packages on Ecklers and they seem to have enough selection of different levels. Granted, I'd like to do this once (for now) and not have to do it again unless it needs it. I don't have 2K to throw at it right now, so I'm going to start with replacing the front drag links and bushings and the sway bar bushings. I'll keep looking.
It does look, however, like the Bilsteins are in my future.
Old Jun 21, 2005 | 02:41 PM
C3nMe's Avatar
C3nMe
While it might be obvious later ...what kind of grease did they send? Was it a silcone based grease, or would normal bearing/ujoint/etc type grease work?
Old Jun 21, 2005 | 03:57 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
That’s a very good system - kind of like this one:
http://www.vbandp.com/detail.aspx?ID=474
Eckler's has distributed our suspension systems for many years now...
As far as coils, The 460 coils on my '78 put my car back to stock ride height (28-3/4"). That looks too high for me but is correct. I prefer the 550 coils the drop the car 1" to 1.75" and Bilstein shocks. The ride is very firm, but not harsh. Hope this helps.
PS - like others have said, be careful with adding a rear sway bar. If your spring rates and sway bar diameters are not properly matched front to back, your car will not be fun to drive, it will be an adventure.
Hope this helps.
Alan G.
Vette Brakes & Products, Inc.
Old Jun 21, 2005 | 04:58 PM
73 Vet's Avatar
73 Vet
Hope this helps.
Alan G.
Alan,
I just ordered the 460's. Have you any idea how much I'll need to cut to get to around 27"?
Old Jun 21, 2005 | 10:36 PM
twistdpair's Avatar
twistdpair
Eckler's has distributed our suspension systems for many years now....
Thanks for the tipoff Alan. If I decide to take the plunge this summer I know how to save a couple hundred...
-corky
Old Jun 21, 2005 | 11:26 PM
rihwoods's Avatar
rihwoods
You can fit a 7 leaf steel rear spring rather cheap and fit Bilsteins and start there.I removed my stock rear bar (FE7 Suspension) when I fit stiffer shocks.This,in my case, meant I had to soften up the rear end to get the balance I needed.So advice you are getting about compatible components is very important...I had to do it by trial/errror...back in the eighties...more expensive to do that today...
Edit....in fact you can do what I'm suggesting for under $600.00.
To Suspension input - 77 L48, 9 Leaf
