Ignition shielding info needed
Old Jun 21, 2005 | 09:49 AM
Skruball73's Avatar
Skruball73
From: Inside every color vette there is a blue one trying to come out!
Default Ignition shielding info needed
My 73 did not have any ignition shielding when I got it. I have since aquired a full set of the shielding. Can anyone get me any diagrams or detailed pics of where it all bolts up to ?
Old Jun 21, 2005 | 10:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Everything you want to know, including the original part numbers, is in the assembly instruction manual (AIM).
Old Jun 21, 2005 | 03:18 PM
Skruball73's Avatar
Skruball73
Thanx, I should have one by Friday.
Old Jun 21, 2005 | 03:26 PM
NHvette's Avatar
NHvette
While I like the chrome top and side channels, I have given up
on those block-hugging V channels.
When I first pulled out my plug wires after buying the vette,
the plug wires were soaked with oil to the point of swelling
to about 2 times the original diameter. It's a neat install, but
not one of the best ideas - IMO. Not to mention, you need
fetus hands to get at the wing-bolts that hold the bottom
of the side channels on. Good luck.
Old Jun 21, 2005 | 09:05 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
If you are concerned about the radio "interference noise", you might want to run a ground wire from your air cleaner lid to the frame. That worked wonders on mine. I can't really explain why it helps, it was a tip another guy gave me.
To Ignition shielding info needed
