toms 12bolt question/problem?
Old Jun 21, 2005 | 09:59 AM
BADDD's Avatar
BADDD
Default toms 12bolt question/problem?
I have something binding up in my rear of my vette. I took out the halfshafts and the Ujoints(1480's) looked/moved fine. I bleed my brakes and drove it around the block and that wasn't it, the brakes had no heat in them indicating a sticking caliper. When the car is in neutral I can't move it on a flat surface. The rear is a toms 12bolt with a 5.13 gear. What in the world would bind the rear up like this? I checked the fluid, looks/smells fine. The car binds then lets loose, binds then lets loose when driving. Im stumped as to what would be causing this, if the posi is broke I would imagine it just would have no posi. Anybody have any idea's?
J
Old Jun 21, 2005 | 10:18 AM
GTR1999's Avatar
GTR1999
With the 1/2 shafts out, did it bind up moving by hand?
Gary
Old Jun 21, 2005 | 10:27 AM
BADDD's Avatar
BADDD
Yes, I can't move it by hand. I can move it with a long pry bar and some old bolts in the axle shafts.
Old Jun 21, 2005 | 10:41 AM
BerniesVette's Avatar
BerniesVette
Did you check the parking brakes? Just a thought.
Bernie
Old Jun 21, 2005 | 10:48 AM
BADDD's Avatar
BADDD
No parking brake on this set-up, good idea though.
Old Jun 21, 2005 | 11:40 AM
lostpatrolman's Avatar
lostpatrolman
It could be part of a broken spider tooth or something floating around and temporarily getting stuck between the gears. I believe GSC3 had this problem with his old setup. It would drive fine, then all of a sudden the rear would lock for a split second then go back to normal.
Old Jun 21, 2005 | 11:50 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
did u set up the pinion right? i grenaded a rear end in my old work that we were doing full throttle donuts in and it did that and i broke spider gears so i think its the spider gears also.
Old Jun 21, 2005 | 11:53 AM
LemansBlue68's Avatar
LemansBlue68
Did you add the GM positraction lube additive? I think one is recommended but Bair's suggested two. I've also heard that there really is no substitute for the additive as others tend to cause problems. Don't know what Tom's recommends but 12 bolts should be no different than the standard Corvette in this regard.
Old Jun 21, 2005 | 12:35 PM
gkull's Avatar
gkull
You need to break it down as to where the problem is: I'd unhook the half shafts at the spindle end by removing the 1/2 the U-joint.
If it rolls and binds that could be as simple as warped rotor. I had one so warped that you could hear it every rotation of the tire without applying the brakes. Up on jacks I could rotate the tire with my hand 1/2 of a rotation and then it wouldn't budge. You also have all the bearings and spindle on the trailing arm.
I've had broken Posi cases and it would still go around - they just make allot of noise.
I also destroyed my first Vette rear end. The case was eaten away on the outside from the yokes grinding on it. when the stock yokes get ground shorter than the snap ring they have so much play the outer yoke end grinds on the case.
I just threw it in the dumpster and bought all good stuff with a 4.11 and custom yokes...... Lot's of tom's parts.
Old Jun 21, 2005 | 12:40 PM
gkull's Avatar
gkull
Are you talking about that rearend in the picture under your avitar?
Old Jun 21, 2005 | 12:41 PM
GTR1999's Avatar
GTR1999
Not good, if you can't move the yokes by hand or the pinion you have soem issues in there to address before driving anymore. Tom usually builds his posi's without the 4 springs which makes it easier to move then the stock setup. With the rear set by itself you should have no trouble turning the pinion and/or the yokes without any binding. Could be broken spider gears, backed out ring gear bolt, crack carrier or chunk of it in there.Keep in mind to fit a 12 bolt there is case grinding and machining required.
I would drop it out and open it up for a look. Let me know what you find and post some pictures if you can.
good luck,
Gary
BADDD's Avatar
BADDD
The rear is not a new rebuild, Iv driven 500 miles or so since I got the car and now its just starting to bind up. Something must have let loose, and I dont know of anything else except the spyder gears that could maybe cause this, broken/chipped ring or pinon gear maybe? Its not a clunk kity cluck sound, just every revolution it feels like something is binding up.
Old Jun 21, 2005 | 12:46 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
$2,450...interesting.
Old Jun 21, 2005 | 12:47 PM
BADDD's Avatar
BADDD
Yes the picture is the same rear. The bearings and rotors spin with out binding up with the halfshafts out. I think gtr1999 is right, i am just gonna have to pull the rear and open it up. Anyone have a 3.90 12bolt gear and posi set-up they want to sell?
J
Old Jun 21, 2005 | 12:50 PM
BADDD's Avatar
BADDD
Luckly I didn't pay the $2450. I really doubt if my 350 could do this with street tires. maybe it was already on its way south.
Old Jun 21, 2005 | 01:02 PM
DJ Dep's Avatar
DJ Dep
I think you are probably right. But that's a lot of samolies to pay and then have it go bad. Glad it wasn't you that got burned!!!
Dep
Old Jun 21, 2005 | 01:09 PM
BADDD's Avatar
BADDD
to that.
To toms 12bolt question/problem?
