Big Block Car?
Old Jun 21, 2005 | 03:48 PM
rdfox1's Avatar
rdfox1
Default Big Block Car?
How can you identify an original big block car? The car in question is a 71. What is different about them mechanically, besides the engine and hood?
Old Jun 21, 2005 | 04:06 PM
luerja's Avatar
luerja
you can first check to see if it is a numbers matching engine.
numbers on engine will be on the front passenger side of engine. Match that to the vin on the front drivers side post.
Jim
Old Jun 21, 2005 | 04:13 PM
Corey_68's Avatar
Corey_68
Check for rear swaybar
Check the redline on the tach
check for to type of U-Joints, BB has "straps"
Old Jun 21, 2005 | 04:14 PM
sxr6's Avatar
sxr6
BB cars have a 4 core rad, a rear stabilizer bar, & bolts & caps on the axle joints instead of U-bolts. There may be other diffs, buts that what I have found out. You may be able to tell what carb or carbs it came with because single holleys had a return line & apparently 3 x 2s didn't, hopefull some-one will confirm this?? You can also get an idea what BB due to redline, 5600rpm for a 390hp carb, 5600??rpm for the 400hp 3x2, the 435hp was 6500rpm? I believe & the L-88 I don't know? Please correct this if any part is not right, I know there's people on here that do know
Old Jun 21, 2005 | 04:27 PM
wildman378's Avatar
wildman378
Originally Posted by sxr6
BB cars have a 4 core rad, a rear stabilizer bar, & bolts & caps on the axle joints instead of U-bolts. There may be other diffs, buts that what I have found out. You may be able to tell what carb or carbs it came with because single holleys had a return line & apparently 3 x 2s didn't, hopefull some-one will confirm this?? You can also get an idea what BB due to redline, 5400rpm for a 390hp carb, 5600rpm for the 400hp 3x2, the 435hp was 6500rpm? I believe & the L-88 I don't know? Please correct this if any part is not right, I know there's people on here that do know
I know a 68 390hp 427 has a 5600 redline
To Big Block Car?
