71 Big Block - Lead?
Old Jun 22, 2005 | 10:16 AM
edxaide's Avatar
edxaide
Default 71 Big Block - Lead?
Should I be adding lead substitute? Most say not, respected mechanic says engine will last longer if you do. Please advise. Thanks.
Old Jun 22, 2005 | 11:13 AM
luerja's Avatar
luerja
nope you don't need to. These were setup to run on 91 octane.
jim
Old Jun 22, 2005 | 11:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
'74 and up heads can run on either fuel. Pre-74 heads are set up to run on leaded fuel and most do not have hardened valve seats. I agree with your mechanic. I run a can of lead substitute every other tank full in my '68. The alternative is to use '74-up heads or have hardened valve seats installed in your stock heads.
Old Jun 22, 2005 | 11:25 AM
Hvymtlc5's Avatar
Hvymtlc5
I just had the soft seat taken out of my 69 heads..no big deal either way.....just make sure and use the lead supplement if you don't want to change the seats.
Old Jun 22, 2005 | 11:30 AM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
All information I've read says that 71 and up heads have the hardened valve seats for unleaded gas...GM was tooling up for when no leaded gas would be around
From personal experience, when I had my heads redone this spring, they took out the original hardened seats (72), so they should be hardened in a 71.
If you're really that worried about it, pull the heads off, and have hardened seats put in.
trw
Old Jun 22, 2005 | 11:53 AM
gerry72's Avatar
gerry72
trw
Actually, they dropped compression (and induction-hardned the seats) in '71 to run on low-lead fuels. No-lead wasn't introduced until '74 with the advent of the catalytic converter.
For '70 and earlier engines, how the engine survives without hardned seats greatly depends on how the engine is used. The higher the exhaust gas temperatures, the higher the probability of the micro-welding that occurs and the valve sinking the seat.
To blanketly say that these non-hardened seats can or will benefit, or whether it's worthwhile to even bother, from a TEL additive ignores the primary consideration of how the engine is used. In a boat or work truck that sees peak torque for long periods of time, sure. For an occasional driver that doesn't usually see sustained operation at peak torque, probably not worth bothering about. At least not for many thousands of miles.
If the engine were going to the machine shop I'd probably have it done. But I wouldn't bother doing it just for this operation unless I was going to be hard on the engine.
To 71 Big Block - Lead?
