Keeping 500+ HP Big Block Cool
Old Jun 23, 2005 | 07:16 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default Keeping 500+ HP Big Block Cool
Just looking for proven combinations with electric fan or fans if need be. Using a moroso electric WP And stock radiator. Just don't want to do it twice. Thanks Ron B.
Old Jun 23, 2005 | 07:54 AM
69ttop502's Avatar
69ttop502
Ron, Griffin large tube aluminum radiator and dual Spal fans from Tom Dewitt. My 625 horse 502 never sees 200. In fact it needs to be pretty hot for the fans to even come on. When they do these things will rip up asphalt. Tom is a terrific guy to deal with as well.
Old Jun 23, 2005 | 08:08 AM
MELVINJ's Avatar
MELVINJ
Ive got the gM 502/502. And Im running the original 427 rad (non aluminum), and with the original water pump, never got hot. Recently I changed out the water pump with a aluminum one
Key is have the rad cored and cleaned.
NO issue with the OEM rad
Old Jun 23, 2005 | 08:19 AM
Hvymtlc5's Avatar
Hvymtlc5
Make sure that pump is for a daily driver not a drag car. The Weiand I had was for strip use only and it looked like a normal pump but flow was just enough to circulate the water.
Old Jun 23, 2005 | 08:23 AM
ImBatman's Avatar
ImBatman
I will be contacting Tom this fall for mine.
Old Jun 23, 2005 | 09:19 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
http://www.dewitts.com/ Great guy to do business with
Old Jun 23, 2005 | 09:20 AM
GDaina's Avatar
GDaina
533 cubes, recored rad, dual Spals. Decided to install the Spals to gain a few horses, if not for that, I'd be using the stock 5 blade fan, plus now it's safer to work under the hood with the motor running.
Old Jun 23, 2005 | 09:55 AM
norvalwilhelm's Avatar
norvalwilhelm
I have the large tube griffin aluminum rad, twin electric fans and run the TRW water pump 30% overdriven and my most of the time I run without any fan turned on. I average around 185 or 190 all the time.
Old Jun 23, 2005 | 12:31 PM
gkull's Avatar
gkull
Altered front end cars like mine have special cooling problems. IMO the real problem with Spal fans is they don't cover the full radiator core.
So I wish that I had gone bigger blades and CFM.
The owners of wimpy motors are happy with Spal fans
Old Jun 23, 2005 | 01:13 PM
jpatrick636's Avatar
jpatrick636
Be Cool Aluminium radiator, dual Spal's (must be a wimp) w/ rheostat, GM pump, no thermostat, Evan's Coolant; 160-180 all day, every day.
Old Jun 23, 2005 | 01:20 PM
norvalwilhelm
George I run 2 16 inch tornado fans, since 2 16 inch fans will not fit I run one low and to the left behind the rad and one high and to the right on the front of the fan. That way all areas's are covered.
I could not get away with just 1 at times. When I really need a fan I need both of them to do the job.
Old Jun 23, 2005 | 01:35 PM
MakoVai's Avatar
MakoVai
Cruising
with 600+ hp I run 4 major items I beleive are the key.
1. High volume water pump (edelbroc)
2. Huge core aluminum radiator (ron Davis)
3. Twin high volume fans (perma-cool)
4. Ceramic coated headers (very helpful)
just my 2¢
Old Jun 23, 2005 | 02:44 PM
Corey_68's Avatar
Corey_68
I'm waiting for the new tranny to get her dynoed. According to Destop Dyno (take it for what it's worth) I'm making 565hp w/ the dual plane and low 600's w/ the dual plane. I have a Griffin aluminum rad, and one 16in Perma-coll fan and on the HWY I turn the fan off and I still run 180degrees. In bumper to bumper traffic w/ the fan on I have yet to see 205degrees.
Old Jun 23, 2005 | 04:41 PM
Lasse's Avatar
Lasse
And the cheapest way... Isolate between rad and hood, minus 10-15 degrees downtown in my case.
Old Jun 23, 2005 | 07:17 PM
Fubba's Avatar
Fubba
just my 2¢
Sorry to get off subject...but that is a monstrosity of an intake.
Old Jun 23, 2005 | 08:34 PM
GDaina's Avatar
GDaina
Altered front end cars like mine have special cooling problems. IMO the real problem with Spal fans is they don't cover the full radiator core.]
Cover enough to keep the temp 180 all day long in bumper to bumper traffic
Who you callin' a whimp you little mousie....
Old Jun 24, 2005 | 12:43 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
825 hp 540"...street driven all the time. Made the 2000+ mile round trip to Bowling Green from Houston the last two years...no cooling issues.
I'm using a stock radiator, a Weiand team G (only 'cause it looks cool- stock pump did fine), stock pulleys and a fixed 7 blade fan.
Good and simple and is reliable on the street.
Never runs hot.
JIM
Old Jun 24, 2005 | 04:41 PM
jpatrick636
That would be me!
To Keeping 500+ HP Big Block Cool
