What do those gizzys under the steering column do ??
I just got my '72 this weekend. I know that the wide black **** and two little round ***** under the steering column at the base of the instrument panel do something in the vacuum override system.
But what? (I don't have any manuals yet.)
Can anyone offer a simple explaination for these?
So what's the one in the center for??
Thanks.
OK I have an idea for what the little ones do. How about the big black one in the center?
I have the standard vacuum problems now, the headlights are up They weren't that way until I first started the car up. It sat for 6 years. I fixed a leaking vacuum line and now the wiper door is open also.
Like was said above:
The little ones operate the headlights and the wiper door.
The big one turns off the wiper in mid sweep for maintenance.
In a properly operating system, the overrides will allow you to open the headlights and wiper door even with the car off. I have yet to see a car with no leaks where this actually works.
Thanks again. I'll see if I can stop the wipers in mid sweep.
It looks like I've got to get the mighty vac out and do some troubleshooting....
You have watched the James Bond Movie: Goldfinger. The LH side **** is for the oil spray, the center is the ejector seat, and RH side is the knock-off tire shredder. Seriously, LH is Headlights, center turns off wipers for maintenance, and RH side is for wiper door activiation.
