Wiper problems
Old Jun 24, 2005 | 10:28 AM
kona's Avatar
kona
Default Wiper problems
Okay last week I did a stupid thing I welded on my car before taking the battery loose. What I ended up with was a buzzing anti theft relay which was an easy fix just replaced it. Also my choke light came on and the choke started acting up another semi easy fix replaced the choke thermostat.
Now it seems the wipers don't work and yes the fuse is good. I did notice a clicking when I turned the wipers on coming from the storage compartment. When I took alook under the liner first thing I got was a nice surprise the orginal jack and handle were there. I also found what looks like a relay attched to a circuit board is this the wiper relay?
Where can I get one?Also there are two other relays mounted next to it anyone know what they are for?
Kona
Old Jun 24, 2005 | 02:19 PM
kona's Avatar
kona
ttt
Old Jun 24, 2005 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What year? On my '80, the wiper, anti-theft, and cruise control (I think) relays are in the jack compartment. The assembly instruction manual (AIM) tells you which is which and has the original part numbers. If memory serves, seems I read where the wiper relays are now very hard to find.
Old Jun 24, 2005 | 02:56 PM
kona's Avatar
kona
Mike my car is an 80 aswell. I looked at my AIM must have over looked it. Do you have any idea if the wipers can be made to work without it?
Kona
To Wiper problems
