electrical problem help
Old Jun 24, 2005 | 09:39 PM
cvet77's Avatar
cvet77
Default electrical problem help
well went to start the other day and car wouldnt start.
There is no power at starter and the neutral switch was alright
any ideas
Old Jun 24, 2005 | 09:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
go back to the basics....clean battery connections, clean grounds, charge battery...use a test light and see where you have power....
Old Jun 24, 2005 | 09:50 PM
Todd68's Avatar
Todd68
More info would be helpful, like did it crank, make a clicking sound, etc.
If by no power you mean no voltage at starter, could be corroded battery terminals, broken cable, etc. If there is 12V @ starter batt. cable connection, then check fusible links, ignition switch, etc. Really need more details to narrow down the possibilities...
Old Jun 24, 2005 | 10:43 PM
71SoCal's Avatar
71SoCal
When is the last time the car ran? Can you jump start it?
Definitely need more info...
Old Jun 24, 2005 | 10:51 PM
cvet77's Avatar
cvet77
battery is in excellent shape will not turn over no voltage at starter
put voltage meter on it.
Old Jun 24, 2005 | 11:01 PM
bobs77vet's Avatar
bobs77vet
and do you have voltage from the big terminal on starter when its grounded to the engine block?
Old Jun 24, 2005 | 11:15 PM
71SoCal's Avatar
71SoCal
If you're certain that your battery is good, than it has to be the cables. (Check battery with voltmeter ~12.5 volts)
Either they're not making contact with the battery posts. (Clean posts)
The positive/negative cable(s) is cut/corroded. (Check each with an ohmmeter)
The negative ground from the frame to the block is bad (Check w/ohmmeter)
If the battery is good and there's no voltage at the starter, it's got to be cabling/cable connections...
StickShiftCorvette's Avatar
StickShiftCorvette
Assuming you have juice at the battery cable on the starter and the starter is OK the most likely causes would be related to no juice to the trigger wire on the starter:
corrosion at the main bulkhead connector that feeds the starter trigger wire (of all the connections there THAT was the first one to give out on my '69!!)
bad connections either to or from the ignition switch at the steering column
shot ignition switch
You should safely (neutral or park) hot wire the starter to see if it turns over before tearing too deeply into the wiring.
Good Luck!
Old Jun 24, 2005 | 11:20 PM
Todd68's Avatar
Todd68
What's the voltage reading at the starter positive battery cable connection (the large one) and what's the voltage at the smaller terminal(s) with key in start & run positions? If I remember correctly, you need a minimum of 7.5 volts at "S" terminal or solenoid won't pull in. Do you hear the solenoid pull-in or click at all when trying to start?
Old Jun 26, 2005 | 08:01 PM
cvet77's Avatar
cvet77
no solenoid doesnt do anything unless stick screw driver between posts on starter then it will turn over
Old Jun 26, 2005 | 08:26 PM
bobs77vet's Avatar
bobs77vet
so the solenoid does work....and the starter does crank....so it seems to me that you are not getting 12volts from the ignition switch to the solenoid .....check out your fusible links.
Old Jun 26, 2005 | 09:37 PM
rihwoods's Avatar
rihwoods
"unless stick screw driver between posts on starter then it will turn over"
Sounds like the spring in the solenoid...possibly...
Old Jul 7, 2005 | 08:03 PM
cvet77's Avatar
cvet77
took starter off and tested it starter was bad good thing got a
lifetime warranty on that problem now solved after putting new
starter on, engine fired right up and it sounds awesome.
thank you all
Old Jul 7, 2005 | 08:05 PM
cvet77's Avatar
cvet77
solenoid bad replaced starter thank you all
To electrical problem help
