Puzzeled with the q jet
You can either get another QJet that's been set up for your engine, or you can hire someone to make all the correct adjustments.
The Q-Jet is a sophisicated piece but not too hard to work on if you take your time. A good reference is the Doug Roe book, Rochester Carburetors (check Barnes and Noble).
Thus, the real trick to a carb is in getting an idle system that works at the desired RPM and vacuum. The 75 Caddy had a 472 BB and idled at around 700RPM. Thus a 350 which I assume you have may not want to idle nicely below say 900RPM. You can try to adjust the idle jet and idle speed to get it dialed in better.
Or, when in doubt send it to Lars...bless his soul.
So a QJet that's been jetted for a Caddy is very likely NOT jetted correctly for a Corvette. Especially if the Caddy had a big block and the Corvette a small block.
It's really cool to see a girl getting into a nice tech discussion. You make some good points. Keep in mind that there are two systems...at idle the main system needs to be shut off, thus a carb must be designed for an engine with the right CFM at the required idle speed so that only the idle system is supplying the juice. Also keep in mind that if the caddy idle was like 550RPM while the vette required something like 750RPM then the carb would probably be fine given that the ratio of cubic inches to carb idle settings would equate to the same amount of air flow through the carb. Luckily, the idle system can be adjusted externally with a screw to assist in idle mixure tweaking, but the transition point can not be adjusted even if all the jets are changed...the transition point is fixed via venturi port size and angle, and the only way to change it is modifying the physical characteristics of the carb venturi. The most common and easiest for a rich carb is to drill a hole in butterflies away from the venturi port openings to allow more air in without disturbing the idle system port that sits right on the edge of the butterlies.
So, at the end of the discussion I would have to agree with you that a BB caddy carb is not likely to be the best match for a sb vette, but I disagree in that I believe it can work fine with only a change in the idle speed of the vette and an idle mixture adjustment. Of course if you are trying to tweak as much horsepower as you can then yes jetting would be an issue too. But, for a daily driver I think a caddy carb would work until a carb with better specs is secured.
Chronically mis-jetted carbs are BAD for engines and BAD for performance and BAD for fuel economy and BAD for the environment. Dumping unburnt gas down your exhaust manifold is a great way to do all kinds of bad things, including fry your cats. Getting an engine to idle doesn't mean that any other parameters are going to be right.
Combustion is a more precise process than "put air and fuel together in a confined space, ignite, extract energy." That's what jetting does -- it makes sure the correct stoichiometric ratio of fuel and air (the "14.7 to 1" ratio biz) is at least close. Yes, an unmodified carb off a reasonable sized V8 might run under some circumstances if you adjust stuff you really shouldn't have to adjust. But why not just put the right damned jets and needles in there in the first place and be done with? I've never jetted a QJet (I've jetted a lot of Mikunis and Keihins, tho ...), but I'm sure there are books and people who can answer questions. Learning to read spark plugs is plenty easy and a very effective way of answering questions about F/A mix under a variety of operating conditions. Come on, this is easy stuff -- don't be lazy!
OK...OK...if you want to get an extra horse or two then fine tuning with jets for a specific engine can be done in the event that the compression ratio is very different, typical air pressure is different (for example high altitude), etc. But, the improvement is minimal compared to the horses gained from timing, exhaust, etc. And, if you try to get that small of a gain by jetting a carb that already has the right jets for that carb under standard atmospheric conditions then you will be re-jetting at the change of the seasons right?
OK...standing by with the face shield down.
er...uh...sorry 81vettelover1, but did you intend to open a thread for a thorough discussion of jetting? If not I'll just shut my fuel port.
You say the car laid down. Is it going rich or lean? If you can tell us the calibration in the carb and if it is going rich or lean we can make some recommendations as to which way you should go.
Be careful when buying parts for this carb. 1974 and older carbs use a primary rod that is a different length than 1975 and newer carbs.
http://www.jegs.com/cgi-bin/ncommerc...51&prmenbr=361
The one you want is 350-1992.
BigBlockk
Later.....
Oh, and glad to hear you've found a place to build your carb. Getting one that's closer to start with should make your life easier.
Also check Doug Roe's book on Q-Jets.
Seems to me, though, I remember a 795 cfm Q-Jet, unless that was what he called the 800 cfm.
