Front Suspension Overhaul w/ Engine Out
Old Jun 26, 2005 | 05:47 PM
79vetter's Avatar
79vetter
Default Front Suspension Overhaul w/ Engine Out
OK, I've got the engine out doing my rebuild and not it seems that its my golden opportunity to clean up the bay and redo the suspension. Do the same instructions pretty much apply to removing the control arms and replacing bushings etc whether the engine is out or not? Or do I have an advantage having the block and radiator out first? ie Can I skip some steps?
Old Jun 26, 2005 | 06:16 PM
Twin_Turbo's Avatar
Twin_Turbo
The advantage is having more room, the downside is getting load on the springs when you need to put them back in, with the engine in you could havs wedged them in there and lower the jack to laod up the lower control arm and connect the spindle, now you have to use a spring compressor.
Old Jun 26, 2005 | 09:14 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
yeah that is a problem i had to put a 2x4 under one tire to get it to compress enough.(i have a lift)
Old Jun 27, 2005 | 11:06 AM
NHvette's Avatar
NHvette
Spring compressor is a pain - unless required for stock (long) springs.
Easiest is to get someone to sit on the fender while jacking.
I installed my front suspension when it was a bare frame.
In the garage, I set the frame on stands - then safely attached
(2) 2x4s that wedged against the overhead floor joists.
This won't work too well with the body on.
Old Jun 27, 2005 | 12:03 PM
jdmick's Avatar
jdmick
Some 100lb. sand bags worked for me.
To Front Suspension Overhaul w/ Engine Out
