1976 Electrical Questions
Old Jun 28, 2005 | 05:54 PM
76greenlar's Avatar
76greenlar
Default 1976 Electrical Questions
I have had my 76 a little over a year, just broke it out of month ***** for this year I have noticed a few things and need a little help.
1. When I turn the car off the tach. does not drop to "zero", when turning the key on just prior to starting it does drop to zero. Should I worry?
2. The "door ajar" light goes on and off when the doors are closed. I have tried pushing the buttons on the door posts to check them. The buttons don't seem to make the light stay on or off. Suggestions please.
3. I am thinking about installing a battery disconnect, to save on charging the battery when it sits for long periods of time like in the winter. I live in Pa. and only drive the car on nice days. Any tips on which type to buy?
Old Jun 28, 2005 | 06:17 PM
JustinGJ's Avatar
JustinGJ
The tach symptoms are normal, at least to my '76 as well. I've seen lots of tachs do that.
The door ajar lights don't run off of the interior light switches, they run off of the switches near the rear of the door, on the car body. Pretty close to the latch striker. It seems totally useless to have these extra switches, and I imagine it would be fairly easy to wire them to the better switches near the front of the doors.
For the battery disconnect I'd look in Jegs or Summit for a real positive on-off switch, and I'd probably just tie it inline right there in the battery box. That way you can just flip the lid and you've got your switch.
Here's a search on summit for the switches, they range quite a bit in price.
http://store.summitracing.com/defaul...ch.asp&x=0&y=0
Old Jun 28, 2005 | 09:39 PM
Bond007's Avatar
Bond007
76greenlar, I have one in the battery box and works great, nice if your somewhere you want added security.
Old Jun 29, 2005 | 10:12 AM
76greenlar's Avatar
76greenlar
Justin
Thanks for the info
76Green Lar
Old Jun 29, 2005 | 10:13 AM
76greenlar's Avatar
76greenlar
Bond007
Thanks for the info
76Greenlar
To 1976 Electrical Questions
