Numbers match ?
Old Jun 28, 2005 | 11:51 PM
TortureTest's Avatar
TortureTest
Default Numbers match ?
This will seem stupid....but when I bought the car i was told the "numbers match". Can someone tell me what exactly this means and how i can ascertain whether mine is a numbers matching car before I kill it with mod's ?
It a 78.
Old Jun 29, 2005 | 12:05 AM
Tom73's Avatar
Tom73
Numbers matching can mean different things to different people. In "general" it means that the engine block has the VIN deritive stamped on it. Look for a flat machined surface on the block in front of the passanger side head. A/C compressor may be trying to hid it. Should be two sets of numbers stamped there. One of them should end with the same 5 or 6 numbers that the cars VIN ends with. If so this could mean that the car has the original engine.
tom...
Old Jun 29, 2005 | 12:58 AM
cosmicvette's Avatar
cosmicvette
Then you can go the next level of 'numbers matching'...like diff,tranny........basically anything that has a part number stamped on it! just depends how involved you want to get...pretty much every part of the car has a part number.
Theres a book out there called "Corvette by Numbers'...check it out or borrow it.
To Numbers match ?
