The stock gear with an auto was a 3.08. In 73 you had options. Anything from a 2.73 (very rare) up to a 4.11. Most came with a 3.08 auto and a 3.36 stick.
You know you can figure out your ratio by putting your car on jack stands and then seeing how many times you have to turn your driveshaft before the rear tires make one complete revolution.
(I'm pretty sure this is how it works, been a while since I've done this, if i'm wrong, feel free to flame and then correct me.)
trw
PLanning on trying this but I believe it can also be decoded from some numbers stamped on it?
If you find your build sheet, I'm sure it is on there. Build sheet is generally on top of the gas tank. Some people remove the little rubber gasket that surrounds the gas tank inlet, and are able to retrieve it without dropping the tank.
I'm not sure if the VIN can be decoded for rear end options.
trw
I am def planning on checking for the build sheet as well. I thought it could be decoded by numbers stamped on the pumpkin itself?
I guess not.
No idea if its stamped on the pumpkin...now I'm curious.
Time to get the jack out and open up the manuals.
Give me something to do when I'm changing oil tonite.
trw
Keeping this thread tracked.....Let me know what you find.
Really curious.
trw
This is the most positive way to determine axle ratio besides pulling the pumpkin and looking at the gears. The numbers can be decoded but if someone has changed the gears before you it is worthless.
I looked for some numbers, but couldn't seem to find any that easily...aka I didn't feel like getting the degreaser out along with a light and do a real thorough search. If I do find any numbers, I'll let you know. I have to go back and add some oil, so when I do that (which will be soon) I'll report back some results.
sorry for the disappointment.
The easy way is to mark the driveshaft and mark a tire then rotate as was suggested above unless you are an NCRS type person. Vette differentials have broadcast codes stamped into them that can be decoded. The factory stamped code is on the bottom of the rear of the differential near the edge of the cover. Look for the first 2 or 3 letters and it could be decoded into ratio, then comes the rest of the characters that gives you manufacturer, date and assembly.
We ARE talking about cars that are almost 25 years old: WHO knows WHAT they have been thru in that time-period.....
