Crate Engine Dyno Tuning Help w/ Video
Carb: Holley 750CFM w/ Vaccum Secondaries
- Main Jetting set a 72 (AFR of 14:1 when cruising at 2700RPM in 4th)
- Idle set for an AFR of 13:1
- No change to Acclerator pump or squirter nozzle (#31)
- Yellow Secondary Springs (lightest)
- Power Valve at 6.5 (Stock)
Distributer: MSD Pro-Billet w/ Mechanical Advance and 6AL ignition
- Initial timing set at 9.5deg
- Total timing set at 31deg (Fastburn aluminum heads)
- Total timing in around 2400RPM
Plug Gap: 0.045"
Plug Wires: 8.8mm Accel wires
Exhaust: Hooker headers w/ 2.5" exhaust and Flowmaster mufflers
We started off the testing with a baseline run with the carb set the same as from the factory and got 290HP. We then ran the car at 2700RPM in 4th to see how the main jets were. From this we lowered the main jets from 74 to 72. We also increased the redline of the motor from 5800 to 6200 based on the power curve. With these changes we got 320HP, but it still appeared to be running too rich (around 11:1 AFR). After several more pulls, we found we had a problem with the secondary diaphram, so we put a quick change kit on and replaced the diaphram. Once this was done we tried the lightest and stiffest secondary springs with not much change in the AFR. This leads me to believe that I need to try different secondary metering plates, but at 20 bucks a pop it will get expensive to try these.
The way we had the Dyno set up, I would "floor" the gas and the dyno would hold the engine at 2000RPM for about 5 sec (you can hear this on the video). I would think that by this point the acclerator pump circuit would be out of the picture and the vaccum was down to 0 so the power valve should not be a factor (it should be open the whole time). Again this is why I think that it is in the secondary metering plates.
Problems during dyno:
1. I checked the adjustment for the rockers on the pass side and forgot to set the poly locks. During the first pull one of the rockers loosened up and beat the **** out of the roller tip. I repaired it, but need to keep an eye on it.
2. In dash tach needs to be calibrated
3. Problem with the secondary diaphram
4. I found out I do not have the rear end gear I though I did since my tach was off. I actually have a 3.73 instead of a 3.55. (I still question this since a 3.73 was not offered and would have to be aftermarket)
I have not tried anything since the dyno and the car seems to drive fine. I have not really got on it since I just installed a new 5 speed and am breaking it in.
If anyone has any suggestions or needs some information, please don't hesitate to respond. I have never tuned on a dyno or with an O2 sensor, so I may be going about it all wrong.
Matt
http://forums.corvetteforum.com/phot...shot-thumb.JPG If you click on "My Corvette Photos" it will show a larger picture
Dyno video
Click here to watch Vette-Dyno1
Anyway what are your secondary jets and you might want to try a mechanical secondary carb like the 4779 or similar so you know the secondary is opeing up for sure. Also have you ever checked to see if when you floor it all four throttle blades are completly vertical, commonly overlooked problem.
And finally, a zz4 rated at 350HP? usually gets about 260 -280RWHP in a C3 from what I have seen, now if you take 270RWHP for the zz4 and apply the same ratio to the zz430 you get 332RWHP
Have you done much with the timing? - cause my car with fastburns tolerates 38 degrees total with 93 octane at 800' altitude and never a sign of preignition. Every suggestion I've seen is that 12 degree initial and 32 degrees at 3000 is the gospel, but mine tolerates 38 total, try some advance if your motor will agree.
Daffy
) work best with 36 degrees mechanical advance all in by 3000 RPM with another 12(?) from the vacuum advance for cruising. The only variable may be the fast burn heads but by the sound of it they require the same specs.
A note: if you don't occasionally clean the pins that the mech. advance springs pivot on, the drag will start to slow that all in point from the 2800-3000 that you want. Only takes a couple of minutes to do, I learned this on a bench with a mittfull of springs and a trigger pull gage.
The 430 would be stouter with a 750 DP as suggested above (I think that's what GMPP uses when they developed them), but I've got good street manners now. BTW, I know my secondaries don't open all the way, most never do, but they are close. I either saw or dreamed up a little goathorn thingy that is on my carb so I can check the secondary opening. A DP opens all the way everytime. Interestingly, about half of the cars that I help people with have the linkage so poorly setup that the carb. never gets full open at all.
I am interested in why the 5.5 PV is suggested above. I've seen a couple of different thoughts on how to determine the valve needed and with my idle vac. at 15"-16" the 5.5 valve seems to be low. Always eager to learn...
Daffy
First some corrections to my original post:
1. Total timing is coming in around 2800RPM (Not 2400)
2. I am at 70 for primary jet size like Daffy2 (I started at 72)
Second, responses to questions:
1. All dyno passes were in 4th
2. Throttle blades are opening all the way with the pedal
3. I did not play with the timing, I had a short amount of time and wanted to get the carb tuned in as best as possible with the adjustments I had.
4. I have though of replacing the meteing plate with a secondary system, but it is a pretty new carb and I just bought and Aeroquip fuel rail that I don't really want to modify. This would probably require me to reset my idle mixture (I may have to do this with a new metering plate as well), and I was hoping that I could get some suggestions for metering plates.
I do have a couple of questions hopefully someone can help me with.
1. The metering plate I have (134-21)has a main hole of 0.081 and an Idle hole of 0.040. Would this be equivalent to having two 81 jets in the secondary? In other words, if I put a secondary system on, could I put 81 jets in and be at the same point?
2. If a carb is not touched but the timing is increased would that changed the O2 sensor reading (richer or leaner)? I would think that with the same amount of fuel and air the AFR reading would be the same. There would just be a point at which your are igniting the charge too quickly (not running too lean) causing detonation.
Thanks for everyones help and opinions
Cheers
Matt
This post made me remember that when I changed the metering plate to a jettable plate I found a lot of casting flash and particles in the carb. The change may be worth doing just to be sure everythings right inside. Please try more timing, I know that the Gospel is 32-34 total but mine is sweet at 38. Also, I asked about exhaust - got a good system?
I'm suprised that your secondaries go full open with a yellow spring, is it the short or long yellow spring?
Daffy
I tore the carb completely apart a couple of years ago when I was still at school and cleaned it in an ultrasonic cleaner in the lab. (I paid for it : ) )
I am going to try and play with the timing in the next couple of weeks and see what it likes. Hopefully I can make it to the drag strip as well.
The exhaust is Hooker headers which I port matched to the Fastburn heads since the port shapes are not quite the same. With a 2.5" system back to a pair of Flowmaster 40series delta mufflers.
20 years apart - that's pretty impressive. You know what they say "Practice makes perfect"
Matt
