Vacuum questions - 1970
I have a white control line running to the engine compartment and over to where it "should" be located but there's no valve there......
The vacuum source that feeds the Climate control panel - it's a black line that connects under the hood with a "T" fitting - Where is the question?
I need to know where the climate control source is connected under the hood. The AIM is not clear.
your should have 4 white vaccum lines
thin 36inch actuator relay to wiper arm vaccum valve
thin 100 inch manaul over-ride valve to "T" connector
thin 14 inch t-connector to RH headlight relay
thin 14 inch t-connector to LH headlight relay
that's a 71 anyway
My wipers seem to work fine and the over-ride works also.
So, I finally found the right page in my 70' AIM which seems to indicate there should be a hot water shut off.
Does anyone else have a hotwater shut off on a 70'?
I've planned on adding one to mine and have ordered one from a 71. It appears in earlier years to be mounted under the expansion tank on the right side. There should be two holes a few inches apart for mounting it on the inside of the fender. Check here for the evidence. Its the best I can offer. I will likely mount mine there.
its a thought anyhow
hawk
