vacuum secondarys
Old Jul 2, 2005 | 08:33 PM
fugawi's Avatar
fugawi
Default vacuum secondarys
how can you tell if they are working correctly.i'm under the hood and try by going wide open throttle. but could not see them move.they are not binding, and seem to open by hand o.k. any ideas would help....
Old Jul 2, 2005 | 09:30 PM
fugawi's Avatar
fugawi
bump
Old Jul 2, 2005 | 09:33 PM
75 Stingray!'s Avatar
75 Stingray!
They would only open under load. What carb do you have?
Old Jul 3, 2005 | 07:03 AM
StickShiftCorvette's Avatar
StickShiftCorvette
For a test, you can make the secondaries open mechanically by putting a small nut and bolt in the closing linkage of the butterfly. If you notice a big change in power then your secondaries are not working right. There are different springs that can be used to make the secondaries open sooner or later depending on your engine's needs.
The other thing you can do is remove the carb, open the throttle and blow air through the primaries (the side with the secondary vacuum actuator) and the secondaries should open.
Old Jul 3, 2005 | 08:39 AM
fugawi's Avatar
fugawi
tanx every one .i'll try those
Old Jul 3, 2005 | 10:36 AM
SteveG75's Avatar
SteveG75
What kind of carb? Demon, Holley, Edelbrock, Quadrajet? Those are good tips for a Holley but not for a Quadrajet.
A Quadrajet is a mechanical secondary carb with a air valve that opens with demand. So, on a Q-Jet:
1) Make sure the choke is disenaged. You can push down on the linkage with a screwdriver to do this or just wait till the engine is warmed up.
2) With the engine not running, open the throttle fully.
3) Now, push down on the airvalve door and look at the secondary throttle plate. It should line up with the baffle in the secondary bores.
4) If the secondaries don't open, make sure that the secondary lockout is not still engaged. It is on the passenger side of the carb and is a pin controlled by the choke that stops the secondaries from opening. Just play with it till it is out of the way, then try again.
The airvalve only opens with demand which is one of the reasons that the Q-Jet works very well on the street.
Old Jul 3, 2005 | 02:16 PM
1971corvette's Avatar
1971corvette
and a smile for the my friends
To vacuum secondarys
