Fuel gauge readings?
Thanks for any info,
---Chris
That's all I can think of for starters.
--Chris
Hope this helps.
Steve
---Chris
Could be an incorrect resistor on the gauge or a bad connection at the gauge/resistor/flex circuit.
There's a resistor on the backside of the gauge connected to the gauge and flex circuit. It is a piece of white ceramic with a color. The color tells the resistance. It is part of the calibration. You might have the wrong one for the year.
Each gauge has a resistor. They are easy to mix up if you take the flex circuit off. You'll end up with some strange readings on all the gauges until you sort them out.
Here are my notes on resistors:
There are color coded calibration resistors associated with each gauge. The first time I took mine apart I didn't recognize them as resistors. They don't look like a traditional resistor. I thought they were just insulators. There are a lot of older vehicles out that and I bet people have mixed them up over the years. They are flat ceramic rectangles that connect between two posts. They are color coded for value. From what I've determined, here are the values:
Disclaimer: I have never found this documented anywhere. It is not in the electrical troubleshooting manual. The color codes are not in the assembly manual. This is by trial and error testing and comparing other known unmolested gauge clusters.
Colors / Measured Values:
Light Blue - 125 ohms
Green - 90 ohms
Dark Blue - 83 ohms
Red or Orange - 85 ohms
I have also seen Pink on the oil gauge and Yellow on the temperature gauge in an original 1980 Vette. I don't know the values.
Here's the results of changing or mixing up the resistors:
Volts - Less ohms = higher reading
Gas - Less ohms = lower reading
Temp - Less ohms = lower reading
Oil - Less ohms = higher reading
The Light Blue (125 ohm) is used on the Volt gauge. If you use something with less ohms, the voltage reads higher. With a Green (90 ohm) resistor, the reading jumps to 18 volts from a normal 13.5V.
Red (90 ohms) is used on the temperature gauge. If you lower the resistor to 40 ohms (test) the reading will lower 25 - 40 degrees.
Dark Blue (83 ohms) is used on the oil gauge. If you lower the resistance to 40 ohms (test) the reading will jump from the normal 30 to 60.
Green (85 ohms) is used on the 77 Gas Gauge. Green on a 77 causes the low fuel light to come on with slightly over 4 gallons in the tank and it will show Full with a full tanks of gas. Red (90 ohms) will cause the light to come on at 2 gallons but the gauge never quite reaches full. Red MIGHT be correct for later C3's that have the 24 gallon tank. I haven't verified this.
Last edited by L82-1977; Jul 7, 2005 at 02:01 AM. Reason: Added additional information
---Chris
