Ok now that the temps are up there here in Alabama, I need to reinstall my A/C. I was wondering before I intall all the components, is there any technical stuff I need to do before they go back in. I know the dryer is probably bad and need a new one but as far as the compresson and hoses is there anything that needs to be done to them? Is there a way to check the joints before I go to have it filled, like pressure checking them? Any info would be greatly appreciated.
Did you actually REMOVE everything from the car? If so, yes, a new dryer is in the cards. Other than that, a good shot of oil, a vacuum, and a recharge should be all you need.
The P.O. of my '73 removed the A/C from it. Fortunately, he kept the pieces & passed them onto me. It looks like I have 99% of what I need in boxes. Hopefully, I'll be joining you soon in the re- world!
Oops! I missed the most important part of your question.
As far as I know, without either a fully charged system, or the manifold set & vacuum pump handy, there's no way to check for a tight system.
But... the el-cheapo compressor-driven venturi-type vacuum pump works very well and the very good manifold sets are only about $70.00 at a regular auto parts store. I bought my own, as I figured that one or two home-recharges would pay for it in shop-cost-savings. It did.
Are you using R-34 instead of R-12 as originally equipped? If yes, I would order a set of O-rings made for R-34 and replace every one...I think Doc Rebuild sells a set. If your hoses are old and/or cracked you may want to order a new set as well. Replacing the drier is not an option...it is mandatory once the system has been exposed to air for any period of time.
How long is a "period of time"? I removed my compressor while I've been working on the engine. It's been a couple of months now. Will the dryer be OK?
There is desiccant in the dryer that absorbs moisture in the ac system. Moisture in the system turns into an acid so you don't want to expose the dessicant to air by leaving the dryer open for any period of time. If you do crack open the system all openings should be taped to prevent moisture from enterring. Dryers are not that expensive, so if in doubt, just replace it.
If I decide to go with the R-34 will the system need to be cleaned out? And if so, how is that done.
Thankd for the replies.
YBnormal...drive a vette
I would recommend you work with a local ac shop for guidance. I replaced all hoses and seals on my car and then took to an ac shop for them to test and recharge. They have the tools to flush your system if they think its necessary. R12 is way to expensive and R34 works great.
Actually, I didn't open the dryer. I just removed the hose connector from the compressor. That shouldn't let in too much air sould it?
