Headlights not working :(
Old Jul 5, 2005 | 12:45 AM
kylem's Avatar
kylem
1st Gear
Default Headlights not working :(
Hey fellas, whenever i turn my headlights on, my passenger headlight will open fine. It works perfect opening and closing. But my driverside headlight will open extremely slowly, and wont even close! I have already put a new relay valve on the driverside and still no luck. Hope u have some ideas.
thanks,
kylem
1974 'Vette
Old Jul 5, 2005 | 08:14 AM
Vette Gator's Avatar
Vette Gator
Many have had good success with replacing the seals inside the actuators. The usual mail order places sell them. Not too expensive and it often solves the problem. In may case, rust was really bad and I had to replace them. I'd look into a rebuild first, though.
Old Jul 5, 2005 | 08:17 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
http://209.183.231.72/corvette-101/vacuum.htm
Start here, great troubleshooting tips. If your headlight is having trouble up AND down it's probably time for a replacement actuator. If it's just trouble coming up then you can get away with the $20 "witch's hat" fix that I was fortunate enough to only need when my left headlight started to act up.
Old Jul 5, 2005 | 11:46 AM
72GACRZR's Avatar
72GACRZR
thanks,
kylem
1974 'Vette
One over looked thing to check is the four springs that assist the vacuum to operate the lights.
To Headlights not working :(
