Front wheel bearings... How often do you adjust???
Old Jul 5, 2005 | 09:39 AM
CGGorman's Avatar
CGGorman
Default Front wheel bearings... How often do you adjust???
Just comparing notes...
How often do you need to adjust your front wheel bearing pre-load?
Old Jul 5, 2005 | 09:53 AM
gerry72's Avatar
gerry72
There is no normal wear in tapered roller bearings. If there is, then you have to replace the bearing and race. So, unless you disassemble the hub to pack the bearings or replace them, once they are set they will stay that way.
Old Jul 5, 2005 | 09:58 AM
norvalwilhelm's Avatar
norvalwilhelm
I agree. If you find they move once set something is wearing and should be replaced. This is not normal.
Old Jul 5, 2005 | 10:15 AM
CGGorman's Avatar
CGGorman
So...every 500 miles is a little too often, huh?
Adding items to winter list...
Old Jul 5, 2005 | 10:20 AM
Z-man's Avatar
Z-man
I'm a stickler for preventive maintenance, so I check mine every 20 years.
Old Jul 5, 2005 | 11:11 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
That is a complete and utter waste of time. Sorry.
Old Jul 5, 2005 | 12:04 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Pack em....set em...& forget em...they'll be good to go.
Old Jul 5, 2005 | 12:21 PM
CGGorman's Avatar
CGGorman
No, you misunderstood. I set them 500 miles aog because they were wobbly and causing severe vibration at highway speeds. Driving this weekend, I noticed they were starting to wobble again.
Sounds like my bearings and/or spindles are breaking down. Are the spindles case hardened? Hardened at all?
Old Jul 5, 2005 | 12:27 PM
rihwoods's Avatar
rihwoods
Old Jul 5, 2005 | 12:30 PM
tigers123's Avatar
tigers123
Default wheel bearings
Front wheel bearings should be repacked every 50,000 miles. Two reasons: fresh grease and inspection. And maybe even a third: peace of mind.
Old Jul 5, 2005 | 12:31 PM
rihwoods's Avatar
rihwoods
Pull them down and inspect your spindles....just in case....but you definately have a problem with those bearings,if I understood your post...
Rich
Old Jul 5, 2005 | 12:32 PM
jdmick's Avatar
jdmick
Spindles should never break down unless you've spun a race. Are you sure you're preloading the bearings enough and then backing off a little? You may have to do this a few times, spinning the wheel between tightenings.
Old Jul 5, 2005 | 01:11 PM
CGGorman's Avatar
CGGorman
I followed the procedure in the chassis manual...I took out the bearings and cleaned them real good since the old grease was...well...OLD. The races and spindles looked fine, but honestly, I didn't look that close. After a good cleaning and drying, I repacked them with synthetic axle bearing grease rated for disc brakes. Packed by hand until grease bulged out of all the gaps. Reinstalled and torqued to 45 in-lbs while spinning the wheels. Backed off the nut until I could get a cotter pin installed (NO back-off needed on one side, and less than 1/8 turn on the other side). After adjustment, they spun smooth and quiet and the ride was vibration-free.
I noticed this weekend that I have a similar (same?) vibration beginning and immediately suspected the bearings again. I haven't checked them yet, but I thought I'd ask what others consider normal adjustment frequency. I've got my answer....
Before the last adjustment, I could wobble the whole wheel on the spindle diagonally about 3/16"...LOTS of play. Maybe they just need re-seated or something. I'll pull it apart this weekend and have a look.
Old Jul 5, 2005 | 01:18 PM
gerry72's Avatar
gerry72
Ah, it may be your technique. You may have overheated the bearings from them being too tight and brinelled the bearing or spun the race. You need to pull the hub and carefully inspect the bearings and races.
Old Jul 5, 2005 | 01:45 PM
CGGorman's Avatar
CGGorman
OK, so what is the proper technique?
Old Jul 5, 2005 | 01:48 PM
iNdigo's Avatar
iNdigo
Is 45 in-lbs what the manual says? That's the lowest preload I've seen before... I've seen specs for 6 ft/lbs, 12 ft/lbs...
If you've gone to the trouble of removing the hubs, why not just replace the bearings while you're in there? Autozone or Napa should have the bearings and seals in stock.
good luck
the blone weasel
Old Jul 5, 2005 | 01:56 PM
iNdigo's Avatar
iNdigo
Check this:
http://www.hotrodders.com/t57071.htm...=wheel+bearing
Personally, I think regardless of what the manual says, you're under-torquing the nuts. If they're old bearings, chances are they have a little more play and need to be set a little more forcefully. But you should *always* back the nut off before setting the pin.
Sometimes you have to just "feel" it. The nut should be just at the point where it's about to come loose; it's definitely not tightly torqued on there.
Also... bearing greasers are like $4, they provide a much cleaner and neater method of packing bearings.
cheers
the blonde weasel
To Front wheel bearings... How often do you adjust???
By Michael S. Palmer | 2026-06-03 09:39:05
