Serpentine benefits?
Old Jul 5, 2005 | 11:02 AM
texaswilkins's Avatar
texaswilkins
Default Serpentine benefits?
What is the benefit of replacing your fan belts with the serpentine setup? Is it worth the $1000?
Bill
Old Jul 5, 2005 | 11:10 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Bill
Well, you've got the more modern appearance. Seriously, though a serp belt does indeed drive a pulley BETTER just because of the size and type (ribbed) of belt. A pulley just will not have a slipping belt unless it's on a frozen device.
For me, it would only be a valid upgrade on a C3 if I was putting in a motor that was aftermarket and not able to take OEM bracetry.
Old Jul 5, 2005 | 11:34 AM
Fevre's Avatar
Fevre
I pieced together one for my Steeriods conversion since I did not have power steering and needed a pump. I spent about $125 for serp set up from an 89 camaro, bought a $20 replacement PS pump just to safe and added a Edlebrock alum rev rotation pump for $150. I am not running a/c so I did not have to deal with an a/c comp.
Old Jul 5, 2005 | 12:11 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Well, I can change a serpentine belt in about 1/4 of the time it takes to change all of the individual accessory belts on a normal Chevy small-block. Plus, it self-tensions. $1000 is insane, hit the local pick-n-pull. Hmm...I may have just talked myself into doing this...
Old Jul 5, 2005 | 12:56 PM
markdtn's Avatar
markdtn
I have a serp setup from a C4 on mine. Main differences are 84-85 has an alternator that plugs right in with no adapting. 86-91 have the small case alternator. 84-87 I believe have an R4 A/C compressor, 88-91 use a Sanden style compressor. You can buy an air pump eliminator kit from Breathless Performance or Dragons Breath Restorations.
I would have thought there would be clearance issues with an F-body setup, but several on the Forum are running it so it must be OK. The C4 has a shorter water pump than an F-body or truck.
Old Jul 5, 2005 | 04:18 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
It's all about the bling bling factor!
Old Jul 5, 2005 | 04:49 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Im not a fan of it. If "1" belt breaks, your out of luck. If only 1 of my V belts breaks, I' at least have another one to run my waterpump and at least 1 of my other accessories. Im just old school though. Serps do look pretty cool though. I wouldn't pay $1000 though.
benefits: probably just asthetics and ease of adjustments - self adjusting with the tension pulley - or whatever it's called.
Old Jul 5, 2005 | 05:16 PM
Empatho's Avatar
Empatho
Old Jul 5, 2005 | 05:27 PM
vetteaddic's Avatar
vetteaddic
I changed the vbelts on my 73 ,got tired of the belts flying off every time I`d get on it and when one belt went the other would follow,and if your worried about losing your one serp belt take a spare,and easy to install,Go to the pick-a-part and look for a 88-92 f-body(camero or firebird)or caprice and get the brackets,pulleys ps pump then get a new water pump...and the a/c if you want if not go to GM and get the A/c delete pulley
Old Jul 5, 2005 | 05:36 PM
WhichVette?'s Avatar
WhichVette?
Serpintine belts are a LOT easier and quicker to change. Carry a spare and a wrench for the idler arm, and you can change a broken one in a matter of seconds.
Disadvantages: Cost to set it up, and can put too much tension on the bearings of the powered devices in a poorly designed system (don't think that's a problem here). Also, if you get a seized up device in the system, you're in trouble.
Old Jul 5, 2005 | 10:01 PM
68/70Vette's Avatar
68/70Vette
The previous posts show the positive cosmetic reasons for the Serpentine belts. They certainly look nicer. My understanding is that the Serpentine belts have less of a horsepowr drag on the engine as compared with the older belt systems. I've seen quotes of 3 to 5 horsepower gain with the Serpentine belt system. Don't really know if this is true, but it seems reasonable.
Old Jul 6, 2005 | 07:54 AM
texaswilkins
That performance benefit was my main concern. I know they look a lot nicer and 1 belt is sure a lot easier to change than getting to the inside belt on a v belt setup.
Bill
Old Jul 6, 2005 | 11:19 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Very nice setup
Old Jul 6, 2005 | 12:52 PM
rihwoods's Avatar
rihwoods
especially if you lose an A/C compressor clutch..and it is locked up...
Old Jul 7, 2005 | 11:28 PM
glen242's Avatar
glen242
Can gain as much HP if I keep the 747 (wide body) wife out of the passanger seat! Sam Kennison (sp.) was right, they put on 2-5 pounds a year. I've been married 43 years. You do the math!
Old Jul 8, 2005 | 07:51 AM
markdtn's Avatar
markdtn
Bill
Jegs has the GM Performance parts version for $7xx with a/c and $5xx w/o a/c.
To Serpentine benefits?
