Smog Question
Old Jul 6, 2005 | 08:35 PM
logansrun73's Avatar
logansrun73
St. Jude Donor '14
Default Smog Question
I'm planning on removing the smog stuff on my 73 L-48. Yhe nuts for the air tubes turn very easy!!!!!!!!!!!! Any ways what size plug do I need to plug the holes at the manifolds? It is all stock. Thanks. Oh one more thing how do u replace the plug wires to the 1,3 and the 2,4 plugs. The block and the engine mount prevent me from getting the wires out. Thanx
Old Jul 6, 2005 | 09:14 PM
73 red vette's Avatar
73 red vette
The plugs on my 73 and 78 are 1/4" pipe thread. Sorry can't help ya on the plug wires. Put new ones on mine and had no problem getting them out or the new ones in. if you have a pic it would help.
Old Jul 6, 2005 | 09:16 PM
page62's Avatar
page62
Is your car registered as an antique in Illinois? Otherwise, you're still facing smog testing...
Old Jul 6, 2005 | 09:35 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
For the plug wires, you can remove the distributer boot from your new wires and remove the spark plug boot from your old wires tape them together. Have a friend slowly pull the wire up toward the distrubuter while you help ease it thru from underneath the car. Works like a top! A fellow CF member clued me in.
Old Jul 6, 2005 | 10:46 PM
logansrun73
St. Jude Donor '14
Thanks guys. Yeah I have antique plates in Illinois
Old Jul 7, 2005 | 10:58 AM
Solid LT1's Avatar
Solid LT1
The threads are NOT! pipe thread, they are a tube thread (1/2" fine thread.) You can buy plugs with the correct thread at NAPA parts stores, Wheatherhead 151X5 is the nuber from memory. I have a set of 2" diamter outlet "Rams Horn" exhaust manifolds for $140 shipped to you if you live within $40 shipping cost of my 94536 Zip code if you wat to look clean when you remove everything. you could also get some 1/2" fine thread Socket Head set screws to plug those holes but, again it wont look very good in my opinion.
To Smog Question
