fuel pump ticking
Old Jul 7, 2005 | 12:50 AM
gator79's Avatar
gator79
Default fuel pump ticking
new overhaul and new cam, now at 3000 to 4000 rpm the fuel pump is making a ticking noise, first I thought it was a lifter. is the new cams fuel pump lobe possibly not as high a lift as the previous cam. do they make longer fuel pump rods or do i need to replace the pump?
Old Jul 7, 2005 | 01:49 AM
Matt O's Avatar
Matt O
I had the same problem and replaced the fuel pump. The odd thing was that the noise started again after about 500 miles. I finally installed an electric fuel pump and put a plate on the side of the block. In both cases the operating lever on the fuel pump showed wear and was slightly loose... Good luck...
Old Jul 7, 2005 | 08:03 AM
Ganey's Avatar
Ganey
Replace fuel pump rod if pump is fairly new. Replace both for PM if pump is old.
You did good to find it- some say "impossible" to find.
The first time I saw that problem, checked the lash, etc.-all good.
Since I can see the engine running in my head, it had to be the fuel pump rod since the pump was new. Replaced to fix.
To fuel pump ticking
