80 front clip
Old Jul 8, 2005 | 01:51 PM
red2blk's Avatar
red2blk
Default 80 front clip
i'm replaceing my 80 vette,front clip myself,can anyone give me some good advice.i have the clip on the frame at this time, but need help bonding the clip to the body.
Old Jul 8, 2005 | 02:55 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Get some big C-Clamps, paint sticks for your gaps and chem-weld to bond it together. You will need to grind off some of the edges and fiberglass some. Body filler to clean things up.
Old Jul 8, 2005 | 03:01 PM
NHvette's Avatar
NHvette
Get it all dry fit and attach it to the firewall with a few sheet
metal screws on each side. This will help to align it when placing
it back on with adhesive. The panel adhesive sets like bondo ...
speed depends on amount of hardener. You run out of time quick.
The screws help to line it up quickly and keep it in place until
the first round of adhesive sets up.
At first, I bonded at the trailing edge of the fender (door edge)
and the top corners/top of firewall. Once that set, I used a ziplock
bag with the corner snipped to apply the adhesive like a cake-decorator.
Using this, it was easy to go back and bond between the fender and
the forward edge of the firewall ... pushing the
adhesive between the 2 panels.
Make sure you get off most of the old adhesive and grind/sand
the surfaces that you are bonding.
Dry fitting with the screws (IMO) is the most crucial step.
Do this with the doors on - then remove doors before using
adhesive. A quart was enough to do mine.
Good luck
Old Jul 8, 2005 | 07:08 PM
red2blk's Avatar
red2blk
Default front clip
thanks for all of your help,i will try your advice.
To 80 front clip
