1980 Overheating.
Old Jul 8, 2005 | 02:14 PM
schi74's Avatar
schi74
Default 1980 Overheating.
My 1980 L48 Vette Starts Out Cool And Remains At 205-215 While Driving. Its When I Come To An Idle After Driving My Temp Steadily Rises Upwards Of 240-250. If I Start To Drive The Temp Comes Back Down To 205-215. I Do Have A Small Squeking/rubbing Noise From Around The Water Pump. The Fan Spins Well And Has Consistant Resistance When Engine Is Cold. This All Happens With The A/c Off. Any Ideas Out There?
Old Jul 8, 2005 | 02:24 PM
rcread's Avatar
rcread
Check to make sure your fan shroud is properly sealed so that the fan is pulling all of the air through, and not around, the radiator. The insulation can fall off which could cause this. Check your timing. If it's too retarded that can cause overheating. Other than that, I would suspect the fan clutch, but it sounds like you've already looked at that.
Old Jul 8, 2005 | 07:45 PM
bigvette1's Avatar
bigvette1
Default Overheating
When was the last time the radiator was flushed out? If not recently or never, might want to pull it out and take it to a shop to be boiled out. Your problem is air flow or put another way pulled air throught the radiator. Also, clean off the condensor coils with a hose. Run on a cold engine the hose from both sides of the radiator and see what kind of gunk has collected.
Run a 180 T-stat and in the summer run distilled water with about 1/2 gallon of antifreeze for lub propterties and a bottle of water wetter. It will lower the temps as water cools better than 50/50 antifreeze.
Other areas to look at are a high flow water pump. At idle you have the lowest pressures.
Old Jul 8, 2005 | 09:51 PM
schi74's Avatar
schi74
thank you. sounds good.
Old Jul 10, 2005 | 12:28 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I have a similar issue. Although as it turns out, not a cooling issue. No one makes the correct temp sending units for 1980 Corvettes. They all read 40 degrees high.
I'm using a cheap mechanical unit as a secondary temp guage. When that one runs high, then I'll know I have a problem.
Here is the thread where I learned my problem: Link Maybe this can help you.
Old Jul 11, 2005 | 09:12 AM
vetteonr's Avatar
vetteonr
Some of the catalogs I have all carry the right one. I have an '80 also. They're about $40 but I just took my old one to an auto parts store and they matched it. It was about $17 and it reads correctly.
To 1980 Overheating.
