Differential leak with pics
Old Jul 8, 2005 | 02:51 PM
more_cc's's Avatar
more_cc's
Default Differential leak with pics
I've noticed since I changed the differential oil that I now have a diff leak... it seems to be coming from the front seal with the main drive shaft since oil is dripping from the front end of the differential;
I've also noticed that it's leaking when I'm driving since there's stains on the exhaust;
I've a couple of questions, how much work is it for a shop to replace this seal?
Is there a breather on the differential that could be blocked and is causing pressure to build up and force oil out through the seal?
Old Jul 8, 2005 | 03:43 PM
Z-man's Avatar
Z-man
Sounds like you just overfilled it. I'd give it a few weeks to see if it stops leaking. (Of course, it would be difficult to tell whether the leaks stop because the correct oil level is reached, or because the diff is empty.)
Old Jul 8, 2005 | 03:45 PM
trainmankjm's Avatar
trainmankjm
Probably the pinion seal. Plan for the better part of the weekend. See my previous thread on '73 Differential Leak.
Old Jul 8, 2005 | 04:02 PM
BerniesVette's Avatar
BerniesVette
There is a plastic vent on top of the diff that is very cheap to replace. Just pull out the old one and push in a new one, costs a few dollars. If the front seal is leaking there is a crush metal seal that needs to be replaced. There is a thread on down the forum where someone did a paper on the complete rebuild on the diff and the replacement of that seal was described two different ways. It should still be on one of the first two pages of this forum. if you can't find it we can give you the details on this seal replacement. First make sure it isn't coming from the sides of the diff.
Bernie
Old Jul 8, 2005 | 07:42 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Listen to Gary....he's the rear end man! That didn't come out right!
Les
Old Jul 8, 2005 | 08:21 PM
more_cc's's Avatar
more_cc's
It's definitely coming from the pinion seal. The car is a 1980 C3 and I didn't think there was a breather, I'll take another look. Also when I filled it up with fluid I filled it until it started to come out of the fill hole, is this right or is there a certain amount that needs to go in?
Finally, I rang my mechanic and he'll do the pinion seal for $100, more if the yoke needs to be replaced as well but instead of spending a weekend under it I thought for $100 it's well worth it!
Cheers for the advice!
Old Jul 8, 2005 | 08:34 PM
1980 454's Avatar
1980 454
yes there is a breather top left side.
To Differential leak with pics
