Gas Gauge Stuck On Full.
Old Jul 8, 2005 | 10:22 PM
schi74's Avatar
schi74
Default Gas Gauge Stuck On Full.
my 1980 fuel gauge is stuck on full. when the tank gets close to empty the needle flickers back and forth from empty to full. any ideas out there?
Old Jul 9, 2005 | 12:18 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Had a similar situation with my 80... Researched the forum and did the following to fix:
* verified that the ground was making good contact (on top of the tank sending unit just below your fuel door and cover)
* removed the fuel sending unit from the tank and used very fine grit sand paper and cleaned the sending coil (will have to remove the sending coil cover once you have the overall unit out of the tank). This fixed my issue.
* if it would have continued...then I would have replaced the sending unit. Go to the Forum Store and I noticed a group purchase for $69.
Let me know if this process does not fix your issue...
Ed
Old Jul 9, 2005 | 09:17 AM
wombvette's Avatar
wombvette
Almost certainly the sending unit. You can check the operation of the rest of the system by alternately grounding the wire at the sender and watching the guage. It should defelect full range each time you ground it.
To Gas Gauge Stuck On Full.
