screwed up timing. Missing something?
Old Jul 10, 2005 | 03:02 PM
62fuelie's Avatar
62fuelie
Originally Posted by MotorHead
This stuff ain't rocket science Check to see if your disrtibutor wieghts are free and the balancer isn't slipping. If those two things are OK disconnect the vacuum advance and plug the line, rev it up to 3000RPM and set the timing to 35 deg and your done
Assuming, of course, that all the mechanical advance is in by then. It should be, but he has no idea of what sort of springs he has or if they are working.
Old Jul 11, 2005 | 02:45 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
If the dampner is old that may be slipping giving you the odd timing readings.
Old Jul 11, 2005 | 09:06 AM
Techno's Avatar
Techno
If you rev it up and get no more mech advance its probably the same situation I had, weights fly out, pull in with very little idle screw change.
I like to set timing on the road anyway. Blast, no ping advance, blast, ping retard.
Old Jul 11, 2005 | 10:32 AM
Kryptonite's Avatar
Kryptonite
Default Timing
Your Distributor Is One Tooth Off Set Damper At 0 Position Rotar Button At 6:00 O Clock Now Try It
Old Jul 11, 2005 | 10:41 AM
Hvymtlc5's Avatar
Hvymtlc5
If the dampner is old that may be slipping (may have slipped) giving you the odd timing readings.
Engine should run after all you have done...IF...you are actually on number one. Pull the #1 plug feel with thumb pressure or straw or something else you can stick in there that the piston is actuall on up on top dead center. Note the position of the damper---it may have slipped before. Set distributer and number one by the piston and see if it runs.
Old Jul 11, 2005 | 08:19 PM
dennis's Avatar
dennis
OK
finally got it! After letting it dry out overnight, I went at it last night. I Set the damper at about 12* btdc, set the rotor with the #1 right one. Cranked and it wanted to strat, so I pushed the distributor rearward and it fired up.
Set by ear and hooked up the timing light. Rev'd to around 3 grand and set the timing to 36*. (good tip from someone here). To be sure, I set the idle, checked the timing. 10*. works for me.
Just for fun, I brought the damper around the 0* and pulled the cap to check the rotor relation to the number one tower. The rotor was just passed the number one tower. So, I guess whoever suggested setting the the distributor ahead of the tower, did the trick. I will be pulling it again to get a better angle for the tach.(oh ,oh)
Thanks to all. I tried everything suggested and some. Been wrenching for a long time, maybe too long, but it's always nice to have extra mechanics in the garage.
Old Jul 11, 2005 | 08:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good job i will buy the next round to celebrate your success!!
