1.How hard is it to convert from power brakes to manual? im racing and saw one of those race set uos whould those work?
2.does anyone have some wire diagrams on the computer for 73 350.I whould order one but i dont have enough time and want to get it started before i leave.
Not sure about your brake question. Most folks are wanting to go the other way.
73 350 computer? Which computer are you refering to? The 73 has no engine management computer, unless someone has added TPI or an aftermarket FI. The stock 73 wiring is pretty straightforward. What do you need to know?
I tried to go the other way when I found a power brake booster in the pile o' parts i inherited...apparently, its not only the master cylinder that changes, the entire geometry of the pedals changes as well. I couldn't just buy a power master cylinder and bolt everything on. I needed the assembly that the brake pedal bolts too. So if you can find a donor car that has manual brakes, takes all that stuff out and put it in your car, and then plug off the vac fitting on the back of the carb. I think.
trw
I will probally just use one of those racin pedal assemblys. Its a race car so i dont want power brakes.
