Well tonight was the first time my car was sitting on four tires in 8 months very impressed just letting everything settle a bit before i torque everything up are the torque specs the same for a composite spring? i also noticed after doing the poor mans alignement the offset t arms sat a little close to the inner side of the pocket almost rubbing according to my lazer level its all within a sixteenth for toe adjustment and for those attempting to use stainless t arm bolts on 2" offset t arms they are too big for the bushing.thanks muchly
The torque specs for the plate bolts is 35-40 lbs. I wouldn't use SS t-arm pivot bolts. They aren't that strong. Never-sieze works great on grade 8 bolts.
