header installation
Old Jul 12, 2005 | 07:10 AM
soccer794's Avatar
soccer794
Default header installation
Ordering the hooker headers tonight trying to install them this weekend. Anyone have any tips on installing them? Any clue about how long it might take me? Its a 71 big block with air conditioning.
Old Jul 12, 2005 | 07:28 AM
72CoupeORG(smc)'s Avatar
72CoupeORG(smc)
it'll take 12 knuckles and all the cuss words in the dictionary and few that aren't!! But really, i've only done small blocks so i'm not much help (just ask my wife)
Old Jul 12, 2005 | 08:34 AM
Hvymtlc5's Avatar
Hvymtlc5
The Hookers ought to go on easily. I have no clearance problems with my 454 and headers. Can do both sides in about 30 minutes...hooking up the collectors and putting in the plugs is what took some time.
Old Jul 12, 2005 | 09:04 AM
johnt365's Avatar
johnt365
i jack the car up, remove the plugs and go in from the bottom. i wish i had a/c. however, in this case it may be a bear.
good luck to you. did you get the cermachrome ones?
Old Jul 12, 2005 | 09:12 AM
Hvymtlc5's Avatar
Hvymtlc5
Both sides in 30 minutes were with the exhaust manifolds already off.....
You might as well figure on 1/2 day, by the time you remove the wires, plugs, pull the cast manifolds, bolt up headers and collectors. Nothing ever goes has planned.
tip : Soak your header gaskets in the sink so they swell a little and seal better (unless your using copper).
Old Jul 12, 2005 | 10:04 AM
rosslato's Avatar
rosslato
make sure to smear anti seize between header and sidepipe or else they be a PITA to get apart in the future
Old Jul 12, 2005 | 11:27 AM
69vettester's Avatar
69vettester
They are a super upgrade for a C3 vette, I think youll love em.
I Installed them on my small block a few years ago. Its pretty straightforward youll get instructions too. Its a one man job but another set of hands when it comes time to bolt to the heads makes it easier. I took some pics of my install If you want to see how it went.
www.weavermill.com/exhaust/hookers.htm
Old Jul 12, 2005 | 01:51 PM
PRNDL's Avatar
PRNDL
Which headers did you order? (It is critical to get the right part#) Are you getting ceramic coating? The A/C could make installation more difficult. I have a 68 bigblock (no A/C) and it took me over a year to install my Hooker Supercomps because I could not remove the drivers side exhaust manifold!!! But I am mechanically challenged. Once I got over that hurdle it wasn't too tough.
An unexpected benefit for me with the coated headers is that my bigblock runs much cooler now.
Attaching the headers to the rest of the exhaust system was another major challenge, and wasn't done properly until I took it to a pro.
Old Jul 12, 2005 | 06:18 PM
an81shark's Avatar
an81shark
took me about 4 hours to remove manifolds and pipes and install headers on a small block.
Old Jul 14, 2005 | 12:20 AM
soccer794's Avatar
soccer794
Well headers have been ordered...1-7/8 ceramic coated for those of you who didn't know...started disassembling the cast iron exhaust today...most of my friends were busy so i enlisted the help of my girlfriend...bad idea...anyways worked for about 3 hours and all i got done was the drivers side i'll post pics after i finish everything...cut a few fingers certainly said those words not yet in the dictionary but I'm half way to removing everything and I haven't messed anything up too bad yet. I'll start the passengers side tomorrow after work...which is after school...which starts at 8...that takes me 45 minutes to get to with no traffic...makes for a long day, but I'll update after I'm done working tomorrow.
Old Jul 14, 2005 | 01:55 AM
Z-man's Avatar
Z-man
I'm installing mine this weekend too - also ceramic coated (Sandersons). Since the instructions indicated that too hot of an exhaust on new coated headers can ruin them, I plan on bringing the car up to temp just long enough to get them hot (the first time), then stopping it and let the headers cool back down. The next time will be longer, etc. Does Hooker mention anything like this??
Old Jul 14, 2005 | 10:42 AM
NC C3's Avatar
NC C3
I got Hookers with pipes coming from JetHot in the next week or so....they were supposed to be here at the end of this week but there was a bit of a delay....thank you hurricane Dennis. Got my spiral baffles off the big brown truck yesterday....so I am "chompin' at the bit"!! Can't WAIT to get 'em on so that I can let the neighbors know.
Old Jul 14, 2005 | 12:08 PM
rosslato's Avatar
rosslato
my exact setup, your gonna love em. they sound AWESOME, enjoy
Old Jul 14, 2005 | 07:49 PM
soccer794's Avatar
soccer794
Well we've reached problem number 1, I have no idea how to get the headers off without removing the a/c...its just not possible, which was kinda expected. How can I remove the a/c? Any other advice?
Old Jul 14, 2005 | 07:53 PM
soccer794's Avatar
soccer794
The other road I don't want to have to take would be to take the car somewhere and have them figure it out...I would hate to waste all the labor in removing the drivers side is there any way I could install the drivers side header and leave passengers side manifold where it is? Seems like this has the potential to mess something up but I have no clue any thoughts?
Old Jul 15, 2005 | 01:39 AM
Z-man's Avatar
Z-man
How long did it take to get your spiral baffles? I see that they don't take plastic. Did you have to send a cashiers check??
Old Aug 10, 2005 | 04:23 PM
Red_Shift's Avatar
Red_Shift
I have a set of Hooker chrome side exhaust if you are interested. I purchased the set for my 1975 but have since installed a big block. Click here to find out what they are. Click here to see what they look like on a car.
The set is brand new.
Bradley Friend
bradley.friend@us.army.mil
Old Aug 10, 2005 | 04:42 PM
Burnt71's Avatar
Burnt71
Yes , Don't forget the antiseize, took me about 2 hours each side. with the old pipes already off. I dont know if I should have done this or not but I never put the bolts in that tighten the collectors to the headers I see no need to .
Old Aug 10, 2005 | 10:56 PM
chris75stingray's Avatar
chris75stingray
you need to use a different bracket.the original ac has brackets mounted to the exhaust manifold. they sell a bracket for this which will allow you to use ac and headers.
http://www.corvetteparts.com/details/iid/91092601.htm
theres no picture but i think thats what you need
To header installation
