Yet another 'car won't start' thread...
Old Jul 12, 2005 | 01:52 PM
Chumpzilla's Avatar
Chumpzilla
Default Yet another 'car won't start' thread...
Unlike many of the others, mine clicks when you attempt to start it, suggesting the starter is getting power and is engaging the flywheel, but it won't turn over.
Just started happening recently. I have a pushbutton start on it right now as I'm in the middle of a resto so I seriously doubt it's any sort of electrical system problem. Nothing else electrically is hooked up on the car. Was starting just fine and then one day, poof..... just a click when I hit the button.... and another when I let off the button.
I'm assuming a starter problem. Any thoughts?
One more thing.... I the valve cover on that side has a pretty substantial oil leak (freshly rebuilt engine) and leaks down the side of the block on that side. Haven't yet fixed it. I wonder if oil could've gotten somewhere it shouldn't in the starter.
Old Jul 12, 2005 | 02:03 PM
jlaw68's Avatar
jlaw68
sounds like a starter silenoid. might want to check the cables too just for grins.
Old Jul 12, 2005 | 02:32 PM
gerry72's Avatar
gerry72
Before spending any money, try this: Get a maximum force adjusting tool (big hammer) and give the starter case a good, solid whack. These things sometimes lock in the housing.
Old Jul 12, 2005 | 02:35 PM
BKbroiler's Avatar
BKbroiler
Discharged battery
Old Jul 12, 2005 | 02:40 PM
Chumpzilla's Avatar
Chumpzilla
It's not the battery. I pulled the battery and charged it.. Same problem. Just to make sure I wasn't crazy, pulled the battery outta my truck and tried it... exactly the same problem. So the battery has been ruled out.
Old Jul 12, 2005 | 02:47 PM
Techno's Avatar
Techno
Solenoind.
also check all main battery connections. On car, battery, terminals.
Pos goes to starter and might be ruled out but negative could be screwing you.
Old Jul 12, 2005 | 02:49 PM
C3nMe's Avatar
C3nMe
I've seen the GM starters work in one of two ways:
1. A "gentle" tap with a hammer to get the solenoid unstuck. It needs to make full travel to engage the pinion gear into the flywheel and then make the high-current contacts. If it stops before full travel, the high-current doesn't flow through the starter motor. Hit it too hard, and you can damage it and you'll be in for a new one (although you may be anyway).
2. The contacts on the back of the solenoid have carbon buildup that are preventing good contact to allow the high-current to travel through properly.
If the tap works, then good news -- but it is likely to get stuck again (it is a common problem with this type of starter setup).
Just my .02c
Brian.
Old Jul 12, 2005 | 02:52 PM
Chumpzilla's Avatar
Chumpzilla
Well, I'll try a gentle love tap with a BFH when I get home this evening and see what happens. I'll also double check the cable connections, but it's highly unlikely that's the culprit. This car is being totally rebuilt, hasn't seen the road in 18 months and was starting up just fine then all of a sudden..... click.
Old Jul 12, 2005 | 04:43 PM
jlaw68's Avatar
jlaw68
if its an auto, make sure to chech the neutral safety switch too
Old Jul 13, 2005 | 08:51 AM
Chumpzilla's Avatar
Chumpzilla
4speed. No neutral safety switch.
Tried the BFH trick last night.... no dice. Checked the cables just to make sure nothing freakish happened. Only thing I can figure is the solenoid went out..... and/or I got oil in somewhere causing a contact problem. I did wipe a fair amount of oil off of it.... but I tend to doubt that one. Dunno.
Old Jul 13, 2005 | 11:07 AM
CrossedFlags77's Avatar
CrossedFlags77
If you take the starter out you can get it tested at any AutoZone to see if its good. Good luck.
Old Jul 13, 2005 | 11:21 AM
jlaw68's Avatar
jlaw68
there is a place in Garland called Master Starter, the guy that runs it is named danny. he is real sharp with starter. we used to send people from the harley shop down there when they needed a starter rebuilt. he could probably give you some insight to what might be wrong.
Old Jul 13, 2005 | 11:36 AM
rihwoods's Avatar
rihwoods
Solenoid spring...maybe....
Old Jul 13, 2005 | 12:01 PM
Chumpzilla's Avatar
Chumpzilla
Hmmm..... wasn't aware that AZ checked starters, CrossedFlags. Maybe I'll try that... would at least point me in the right direction.
Old Jul 13, 2005 | 01:39 PM
stingr69's Avatar
stingr69
Jump the fat starter terminal to the small terminal on the starter using a screwdriver and see if it cranks. If it does, you have a problem with excessive resistance in the starter trigger circuit. If so, it can be solved with the Ford relay mod. If not, you have problems with the starter or the main voltage.
-Mark.
Old Jul 25, 2005 | 08:46 AM
Chumpzilla's Avatar
Chumpzilla
Just an update on my situation. Techno ended up being closest. A bad connection at the terminal clamp caused the problem. Poor connection where the cable is clamped into the terminal clamp on the positive side wasn't getting me enough current to crank. Took the clamp off... cleaned it up... snipped off the end of the cable and made a fresh new connection. Reattached the cable... started right up.
Just something else to check for anyone else with similar problems
Old Jul 25, 2005 | 09:03 PM
fugawi's Avatar
fugawi
To Yet another 'car won't start' thread...
