I am having a turn signal problem that I haven't ran into before.
Right turn signal works perfectly, left signal will blink slowly 5 or 6
times then quit blinking but the lights stay on just not blinking. Can
someone point Me in the right direction to start looking for the problem.
Thank You, Dennis
check the ground wires & bulbs on your left lights,you also need a new flasher unit, it's located near the fuse box under the dash. its a about an inch in diameter about an inch in height, pull it right out and go buy another, about $2.50, but that was 5yrs ago.
