I found this while checking up on some mufflers I was thinking about buying, and I remembered that a bunch of people were pretty interested in this article when it first came out several months ago...just thought I'd post it for those who are interested in reading it.
Vizard seems to have become a wizard at trotting out 1980's era advice and calling it new.
Granted most people havn't a clue about exhaust systems but telling people, for example, that equal length headers don't make a difference is a gross disservice.
It's an OK article but it's not the only thing you should read.
Gross disservice or not, it happens to be TRUE. Equal length headers are more suited to RACE engines where the headers are run wide open.
For street use, Tri-Y headers are MUCH more effective.
Glad to see you back on the forum.
What company makes a tri-Y header for C3 vettes?
I'd be interested, since I'm more in the street/strip crowd then anything else.
trw
PS: Do you need a set of Hooker super comps for your 302 you're going to build? If you do I've got a set.
trw
Hi Ted
That's the tricky part. Most likely they will have to be fabbed by an exhaust builder. People are so sold on the 4-tube equal-length that that style header gets major coverage.
Stan's (the last website) shows a Tri-Y for a Vette, but not sure which year it fits.
Doug Thorley is big into Tri-Y headers and he may have a set for a C3 Vette. Summit carries Thorley headers.
I could sure use those headers you have, but I'm getting ready for a big move to New Mexico and don't want to accumulate any more stuff.
Dep
Equal length is most important on the street. The biggest difference they make is not in Max HP but rather in tuneability.
The exhaust contributes 100x more to the manifold vacuum than the intake does ( Vizards own words ). Haveing unequal length tubes means some clyinders are running lean, some rich, none where you want them.
( this is one of his many contradictions )
Tri-Y headers have never been proven to be better than a properly designed set of equal length headers. They may be better than 90% or the garbage out there but that doesn't mean they are good!
When I switched from non equal length headman side exit headers to a set of properly designed headers I ganed 5" of vacuum. Thats what matters in a street car. Oh, and that is through the mufflers.
Personal experiences aside, it's been common knowledge among most hot rodders for MANY years that the Tri-y design is superior to 4-tube for street use.
4-tube headers are great...uncorked and running wide open at the strip.
For the street, the best thing they do is reduce weight over the stock manifolds. Some folks just refuse to face facts and prefer to be brainwashed by advertising. Ah well...someone has to keep those 4-tube header companies in business
BTW...I'll take useable HORSEPOWER over vacuum any time!!!
If that 80's advice was no longer relevant, I'm sure he would have noticed while he was continuing to win races and actively involved in research... http://www.coe.uncc.edu/college/vizard.htm
So I'm a little biased, I'm starting there in the fall
Why don't car makers use "Try whys" if they work so well on the street?
I mean they use "headers" don't they?
Car makers normally use whatever is cheapest and relatively efficient. Car makers are more interested in installing stuff that won't wear out within the warranty period than extracting the maximum performance from the engines. Tube headers on daily drivers do not last long unless they are given expensive coatings. As far as I know car makers have NEVER installed factory tube headers on ANY vehicle from the factory. Even the much-admired L-88 came with the same exhaust manifolds as a normal 427.
I'm talking about those tubular manifolds. Seems like it would be economical for the new vettes to have the try-y style even if it wasn't optimized, just as the things aren't for 4-1.
Having unequal length tubes means some cylinders are running lean, some rich, none where you want them.
Well, here is some more "1980's era advice" but I think it is still relevant to this discussion. Especially since the web site you recommended (Headers by Ed) mentioned Smoky Yunick's comments in Circle Track magazine on the relative importance of good header design as an example "of actual good advice given in a magazine."
"For many years we stressed the importance of equal-length primaries, but it is important to realize that equal length is not the only consideration in header design. The ultimate test of a good header is equal flow through each primary tube. Even though all the primaries may be equal in length, if some of the tubes have more bends in them they will be more restrictive. As an example, if one tube has two bends in it and another tube of equal length has four bends, the one with four bends will not flow as much volume as the one with two bends!
So it is very likely that a properly designed racing header will have primary tubes that are not all equal in length. You may want to keep this in mind when you buy or have a set of headers fabricated. Unfortunately, it is impossible to just look at a header and tell how efficient it is—the only sure way to tell is to use flow testing—but the important thing to remember is that equal length doesn't necessarily mean equal flow." Smokey Yunick's Power Secrets by Smokey Yunick with Larry Schreib, copyright 1983
